Question about LG RH177 DVD Recorder/HDD Recorder
LG RH177 Recording
I have set this machine up to Time Record it goes through the motions but records nothing. When I push the "Instant Record Button" it starsts recording but after a few minutes it shows an error message(Record Blocking Signal Received" Reording stops. On playback everything appears normal. I suspect the SCART socket Can you help Ed Pedersen
  • sorrel Nov 05, 2007
    I pretty much have the same problem, I set up timer recording, it comes up on my tv screen '5 minutes to timer record' and then it records nothing!!! I didnt know I had to put the machine into standby mode after setting up the timer record. I will try that tonight when I get home, and hopefully that will solve my problem. Thanks!!!
Once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Posted on Oct 17, 2007
SOURCE:
Have a swann DVR 4_950. Let's u set up to record. Shows the motion sensor icon and says it set to record. But when I went to watch it. It said empty HDD. Anyone know what to do.
Go into your Record Menu then Record Schedule and make sure you have green set for recording motion. Other thing to check is record speed to make sure the frames per second are set. If the record icon shows up next to the motion icon then you may have a hard drive issue. Try to reformat
Dec 03, 2017 | SWANN Home Security
LG HDD RECORDING WONT STOP
Did you try to contact LG support?
Nov 19, 2015 | LG RH1999H DVD Recorder/HDD Recorder
Subtitles appearing on screen in recording mode on LG RHT497H
You are confusing subtitles with closed captioning (CC).
Nov 19, 2017 | LG RH177 DVD Recorder/HDD Recorder
Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
How to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
May 29, 2009 | LG RH177 DVD Recorder/HDD Recorder
Recording
check time clock and did you push the power button off?
Oct 11, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Timer recorder n/w
the recorder must be off, otherwise timed recording doesn't work
Aug 29, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG HDD/DVD Recorder RH177
the original program must be unedited - see response to http://www.fixya.com/support/t384103-lg_hdd_dvd_recorder_rh177
Feb 09, 2008 | LG RH177 DVD Recorder/HDD Recorder
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
HDD to DVD
make sure you set dubbing speed to sp ,short play,thats the default setting,then go to start up menu and finalize disk
Oct 11, 2007 | LG RH177 DVD Recorder/HDD Recorder
LG RH177 DVD Recorder/HDD Recorder Logo
390 people viewed this question
Ekse
