Question about Kenmore 22422 Top Load Washer
Kenmore series 110 (several years old) agitates, but won't spin or drain
I accidently overloaded my washer (I tried to wash pillows). It stopped itself at the beginning of the spin cycle and now it won't spin at all. I removed the items and tried it on various cycles, so now it has water in it and it won't spin or drain! The dial advances itself automatically until it gets to the end of the agitate cycle. There was no smell, and there are no noises or movements, so I am assuming (hoping) I didn't burn the motor or belt or anything??? I am wondering if there is a breaker that got tripped within the washer? I know drum-style machines sometimes have a button you can press to reset after an overload trips it. Anyway, I'm not very handy, and I'm a renter, so I am hoping to find a simple solution that won't make me call a repairman!!
  • aprilq Aug 14, 2007
    I took apart the cover (thanks for the detailed instructions), and found that the housing had cracked where the screws attached the switch to the lid. The part that the appliance guy sold me was COMPLETELY different from the one in the machine. I used epoxy to repair the cracked housing, but the machine still does the same thing. I am assuming that the whole switch is bad, so I will take it with me when I go back to that store. Hopefully this will solve the problem, and I will keep you posted. Mahalo (thank you) for your help.
  • aprilq Aug 20, 2007
    Update: I finally got the right part, and the washer is working!! Thanks again for the great detailed instructions. I will never be intimidated by a large appliance again! (Yeah right). But I can honestly say it was easier than giving birth, another feat that I recently accomplished for the first time. Thank you so much.
    President:
  • 331 Answers
April! DO NOT REMOVE THE BACK OF YOUR MACHINE!!! THIS IS NOT HOW YOU ACCESS THE PROBLEM!!! The problem is the lid switch. Look at the bottom of the lid, see that plastic "striker" on the right side? It fits into a slot in the top panel of the washer when the lid is closed. Underneath that slot is the lid switch held in place by the 2 screws you see there. UNPLUG YOUR WASHER!! OK, to access it for replacement... close the lid and look at the front of the control panel, on the far left and the far right you'll see "trim" pieces. Use a small flat screwdriver and pry these up and away from the panel, then remove them (they just snap in place). Exposed, now, are a phillips screw under each, remove these and set aside. Now lift and rotate the entire control panel up and out of the way. Now look on the far left and the far right again, you'll see 2 brass looking locking tabs. Use your phillips screwdriver again (this time as a prying tool) and poke the blade down into the top of the lid, then pry backwards (pushing the handle of your screwdriver toward the wall). The clips will pop out... set them aside. One more thing to disconnect... Look at the top panel, now exposed 'cause the control panel is out of the way, you'll see a white electrical connector with 3 wires (green, white and gray about 12" from the right side of the machine), remove this. OK, now to access the lid switch! Lift the lid and rotate the ENTIRE front cabinet toward you to about a 45 degree angle, then pull it out and away from the washer. Now you can remove the 2 screws holding the lid switch in place and the ground wire from under the cabinet. Then unplug the white connector away from the cabinet. Now you have the part in hand. Your model number (above) is not enough to go on for me to get you a part number. The model number is located on top of the cabinet, under where the lid hinges, in the center. Call your local appliance parts retailer and give them the model number OR take the now removed lid switch to them and ask for a replacement, (they WILL have one in stock for about $25.00). Installation is the exact opposite of removal. Sounds like a nightmare job, but it's not. Average time for your first one is an hour. (I've done so many, I can almost do it blindfolded in 15 minutes.)
Posted on Aug 13, 2007
  • Tracy Farrell
    Tracy Farrell Aug 14, 2007
    Way to go on your first lid switch access! Good job! Let us know how it turns out.
  • Tracy Farrell
    Tracy Farrell Aug 21, 2007
    Good job!!! Your first major appliance repair! Feels good doesn't it? Congratulations on your New Born, as well!
  • 641 Answers
Open washer's rear panel first and look that belt wasn't broken or moved from its place. Look as well if motor spins. Let me know with your results and we will see how can we assiste you. Good luck!
SOURCE:
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore Washer Will Not spin
replace door switch ,good luck APPLIANCES R EN
Mar 03, 2013 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 70 series 110 washer won't drain or spin, but agitates
You have a broken lid switch. Check to see if the switch is broken off of the two screws that hold it under the lid. If it is, get a new one, take off the case and replace old switch with the new one.
Apr 06, 2009 | Kenmore 24932 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
61 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
