Question about Canon PIXMA iP1600 Printer
Waste ink absorber on canon iP 1600
Hi, I keep getting an error message that the waste ink absorber on my canon iP 1600 is full. Iknow that by hitting resume fixes the problem temporarily, how can i clean the ink absorber so that the message stops for good?
  • 33 more comments
  • Anonymous Nov 20, 2007
    same
  • Jen12 Dec 11, 2007
    same problem as me thanks for the help. Hope it works.
  • mptathwell Jan 02, 2008
    Had the same problem with the waste ink counter on a Canon Pixma iP1600. This fix cured it - so well pleased thank you.
    Would be interested to know hwre the waste ink filter is so I can try to clean it out though before further problems arise - or does anyone know that its not a problem?
  • Anonymous Feb 12, 2008
    my canon printer ip 1600 says the waste ink absorber is full and I have to push the on and off switch to make it print . Nothing in the manual Any advice? Cape Town
  • nedition Feb 13, 2008
    ip 1600
  • Steve vC Feb 28, 2008
    Same problem. Canon 800 help says you need to get fixed at canon repair facility.
  • jamil95 Feb 29, 2008
    Repeated inability to progress printing because of [Waste Ink Absorber is Full'
  • Priyanto Mar 06, 2008
    Dear, All.
    I have proble my printer Canon Pixma iP 1600 :
    The Waste ink absorber is full, contact the service center for the replacement at the waste ink absorber
    thx
    Priyanto
  • Anonymous Mar 13, 2008
    I have problem, Message appears saying Ink Waste absorber full, needs replacing, what should i do? ip1600 Canon
  • Anonymous Mar 14, 2008
    Our canon pixma iP1600 printer is showing the same message and I don't know where to find the waste ink absorber.
  • Anonymous Mar 25, 2008
    WASTE INK MESSAGE KEEP ON POPING UP, WHAT DO I DO
  • Evelina May 05, 2008
    I had the same message, but now it's full! I have tried to do disconnect, and the message does not go away and it does not print!!! What can I do???
  • Anonymous May 22, 2008
    my printer say the same thing call service center for replacement of waste ink absorber
  • lusie May 31, 2008
    yes, I do have the same problem and expected to see the solution as the site is Techincal Support and instructions!!
  • newmacer Jul 13, 2008
    Hi, I keep getting an error message that the waste ink absorber on my canon pixma  iP 1600 is full. Iknow that by hitting resume fixes the problem temporarily, how can i clean the ink absorber so that the message stops for good?
  • watercolor Aug 04, 2008
    I have looked inside and found nothing. I have removed and put ink cartridges back in.
  • penny705 Aug 11, 2008
    I took out the grey foam strip looking for access to the absorber, but couldn't find it.
  • Anonymous Sep 01, 2008
    When i went to print a song my printer said my ink absober is almost full
    I don't know were it is or how to clean it
    cannon printer pixma ip1600
  • shizle Sep 08, 2008
  • Anonymous Sep 10, 2008
    Well I had the same problem, but upon inspection inside for the waste ink absorber, I found a massive big BLOB of INK all over the big nylon gear, so I guess the whole unit is now shot...
  • Anonymous Oct 30, 2008
    ink absorber full lights flashing won't reset?
  • metrofire752 Oct 30, 2008
    I have the same problem what do I need to do to get it off?
  • Luz Alves Oct 31, 2008
    Message I am getting is - " the waste ink absorber is full". My printer (iP1600) stopped printing. What is the next step to do?
  • swingnlilly Nov 06, 2008
    after a page prints, I get a message "waste tank absorber is almost full to resume printing, press the resume button on the printer"
  • Anonymous Dec 03, 2008
  • Runnergal Dec 27, 2008
    I have had the problem a couple of times and I did what " Guest " did ( posted in May 2008) and it worked both times.
    I know have the solution posted beside my printer.
    Thanks Guest you saved my life.
  • dhodgesroof Dec 29, 2008
    I get "Waste Ink Absorber is Full". I don't know where it is (I can't find my manual!) so that I can clean it.
  • Anonymous Jan 23, 2009
    En mi caso la impresora ya no me deja imprimir y necesito saber que parte de la impresora debo limpiar y como debo limpiar para que trabaje normalmente
  • Anonymous Mar 03, 2009
    i actually think mine is full as it is blotting the right side of the page before beginning to print, which is an annoyance for my projects.
  • Anonymous Apr 17, 2009
    "Best Solution" worked for me. Thanks!
  • Anonymous May 01, 2009
    Solution #1 worked for me too.
  • Anonymous Mar 12, 2014
    I have an error coming saying that the ink absorber tank is almost full how do replace it or clean it and where are they available in Australia
  • Anonymous Mar 23, 2014
    mp160 printer error messages 2 and 7 plus shows ink absorber full
  • Anonymous Mar 25, 2014
    How do I clean the ink absorber as it is giving me a message that the ink absorber is nearly full
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Posted on Nov 30, 2007
There are 2 Parts to Fixing this problem.You can do both or just 1. I do recommend that you do both, otherwise your printer might leak ink in a few moths!
1. Remove the ink pads and clean them.
This is not as hard as you might think, lets start.
- Remove the ink cartridges.
- Open the front cover of your printer.
- there are 2 screws holding the outer cover of your printer, unscrew them.
- Start lifting the cover up, take a flat srewdriver and on both sites of the printer are nodges, put the srewdriver in and twist it
Posted on Jan 26, 2009
Solution # 2 worked for me. It's simple, easy, and worked right away. Thank you.
Posted on Jan 30, 2008
    New Friend:
Reset Ink Counter-Level Canon iP1600 1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Posted on Dec 25, 2009
    President:
  • 1,114 Answers
Most likely the pad will not need cleaning, the Canon software detects the waste ink in a small tank below the pad and causes this error. You can reset the waste ink counter by following the procedure below: 1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset. The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2007
My cannon Pixma iP 1600 always says ink absorber is full so cannot print anything. What can be done?
Posted on Nov 02, 2008
It is not a permanent solution, if you disconect the power cable the problem reapears.
The permanent solution is with a prog.....
Hwo nows what I am tocking about ???
a link ???
Posted on Aug 10, 2009
Posted on Sep 16, 2008
I tried a few times... I have done this alot to many different canon printers. This is what worked for me.
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Good luck. I was very happy when this worked for me.
B's
Posted on May 05, 2008
  • 2 more comments
  • RevRichard59 Aug 25, 2010
    This seems to have done the trick. Thanks for saving me the cost of a new printer!
  • Mellow P Oct 26, 2010
    Thanks solution 1 worked for me. Mellow P, 27/10/2010
  • breueh_09 Oct 28, 2010
    Thanks for solution 1 worked for me, very use full, [email protected]
  • kayin_1993
    kayin_1993 Jan 20, 2012
    Cleaning Waste Ink Absorber Cannon IP1600 without tearing the whole printer apart(theres no need to, really.)
    Materials needed:
    Cotton buds, tissue paper, warm water,long tweezers/ Chopsticks (its quite useful if you know how o use it),toothpick/something with a fine end, torch
    1)Unplug the printer. Put it on you desk so its easier to work with.
    2)Lift up the cover of the printer. There should be a whitish kind of tape-like ribbon attached to the ink cartridges. The ink cartridges should be the the very right end of the interior of the printer.
    3)Gently pull the ribbon the is attached to the cartridges so as to expose the waste ink absorbers that nest directly underneath the original position of the cartridges. For your convenience you can just pull the cartridges to the very end so you have a bigger working area. The waste ink absorbers are really tiny,hard and flat pieces of material that are around 1+ to 2cm long in breath and length.
    4)Using a torch, locate the waste ink absorbers (2). They should be held by two small black flaps each. If you are really not sure just use a tissue and feel around. The area where you get a exceptionally much ink stains should be at/pretty near the absorbers. Using tweezers/chopsticks, remove the absorbers carefully(don't lose it). You might wanna clean up the interior abit using cotton buds..
    5) Press each absorber gently in between layers of tissues to get some ink out first. After that just rinse it with warm water. (I just used warm water, but if you have cleaning agents you can go ahead and use them) Dry it in between layers of tissues and air it abit for further drying.
    6) After it is dried you can put them back to their original positions. Keep them in place with the flaps on the sides. The flaps can be easily put in place with the help of toothpick/fine end objects. If you cannot reach the flaps just use the tweezers to help you with it.
    7) Next up, at the base of the interior of the printer you can feel something soft and spongy. It looks like a long grey piece of delicate sponge. Clean that too if it is dirty. Replace it after cleaning and drying. Be careful not to tear it and remember to put it back securely, by using cotton buds to tuck it into place, if not it might interfere with printing process or come lose while printing.
    8) Reset your waste ink counter (there are walk-throughs online) --->http://tricks-collections.com
    9) If not reset your printer. I did.
    [ Step 1 : Manual Temporary
    1. Unplug power and USB.
    2. Open cover and hold power button.
    3. Connect the printer cable.
    4. Close door, then release power button. ] ---credits:http://printertools.blogspot.com/2007/12...
    Kay thats all folks! I had a REALLY TOUGH time trying to figure out all these myself, GAWD. Hope my experience will be helpful to you though! :)
These method solves the problem until you disconect the power cable again, after that the problem reapears and must be resolved again.
I read somewere abut some tiny prog that rsolvs these problem, ?????????????
There seems to be something wrong with the instructions given by Informatica. I have tried following the directions with my Canon Pixma IP1600, but can't make it work.
Regards
Don
Posted on Nov 26, 2007
    New Friend:
Where are the ink absorber pads located on mp470 canon printer?
Posted on Dec 15, 2009
    New Friend:
I followed Soution #1 and was able to remove ink cartrigdes. But where is the ink absorber located and doesn't that need to be cleaned/emptied if full as indicated by the error message?
Posted on Dec 13, 2009
I can confirm that this (ie. resume x4) works for the iP1500.
Posted on May 15, 2008
I seemed to have solved this by:
Turn off printer
Disconnect cable
Press and hold on button whilst connecting cable
Green button will be on
Press and release resume button
Press and release resume button again
On button should go green and all be well
I turned the printer on and off a couple of times and printed just to check.
Posted on Nov 28, 2007
2 Suggested Answers
SOURCE:
  • 518 Answers
SOURCE: Waste ink absorber on canon iP 1600
Try reading THIS .
Hope that fixed ya...
Geno
Posted on Apr 04, 2008
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My printer canon ip 198 shows error e5..what should i do?
Hi there
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Feb 23, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hi, I have a Canon PIXMA iP 1600 printer. Recently, I started to get a message that says: The waste ink absorber is almost full. Press the printer's RESUME button to restart ...
I have a Cannon PIXMA ip 1600 printer. Recently, I am getting a message that says: The waste ink absorver is almost full. Press the printer's resume button to restart printing. What is this ? How to solve this problem ?
Jun 15, 2009 | Office Equipment & Supplies
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Error message
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Jun 30, 2008 | Canon PIXMA iP1600 Printer
Try reading THIS .
Geno
Apr 04, 2008 | Office Equipment & Supplies
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
Canon PIXMA iP1600 Printer Logo
26,715 people viewed this question
Clive
Clive
old marine
old marine
Ekse
