Question about Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat
Rinnai fan stops turning.
I have an old rinnai wall heater in my home and the rotory fan at the base of it keeps cutting out. If I reach into it and spin it manually it will runf for maybe 10 - 20 minutes but then cut out again. Is it easy to remove and clean all the dust build up out?
  • 1,420 Answers
You can reach the fan wheel by using a can of compressed air normally used to clean your compute keyboard. Make sure you hold a vacuum wand close to the heater when doing this to collect the debris. Using a small coffee stir straw, lubricate the end of the fan motor shaft with light motor oil. This will keep the motor alive for a bit longer.
Posted on Aug 30, 2007
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Gary
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
We have Rinnai in wall heater. when it is turned on it runs for several minutes before the gas cuts out
Currently, there are 3 models of Rinnai in built radiant heaters. Could you please provide the model number of your heater?
Thanks for choosing FixYa. Cheers
Aug 26, 2011 | Heating & Cooling
Need pilot light assembly for Rinnai gas heater model #REH-25-P
Unfortunately, Rinnai only sells repair parts through their authorized dealers. Contact the dealer you purchased it from. If you are not the original owner of the home/heater, you can go to Rinnai's website and search for a dealer near you. http://www.rinnai.us/direct-vent-wall-furnaces/
Feb 28, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Avenger 25 error 13!
thermocouple high cut out on convection fan rinnai fitters job , have to wait sorry , it is in the manual under fault codes .
Jul 06, 2010 | Heating & Cooling
I have a rinnai heater and it stopped working all
rinnai, toyostove and monitor heaters are basically all the same. first you have to make sure your fuel valve is open at the tank. next you have to reset the tank lockout on the sump. then set your set point higher than your room temperature. now press on. the unit will go through a 300 second purge cycle. the pot heater should turn on when the purge cycle starts. after the purge cycle the fuel pump turns on and pumps fuel into the pot. when it vaporizes the igniter lights it. when a flame is detected the flame rod says ok to keep running so the fuel pump shifts into high speed. when plenum temperature reaches a preset level the fan turns on.
Oct 17, 2009 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Jul 07, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai water heater continually running
the rinnai comes on when water starts flowing through the unit.
Apr 08, 2008 | Heating & Cooling
Rinnai monitor heater 1004F
http://www.rinnai.us/Rinnai.aspx/FileLib
hope this helps
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 556
money seems to be an issue for lots of us. but if you don't mind a coupla extra bucks get a few axial muffin fans and use them to spread out the heat pattern at your bedroom doors
Jan 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat Logo
286 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Hjalmer Lamminen
Hjalmer Lamminen
Craig Butler
Craig Butler
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
