Huawei At&t Fusion Prepaid Android Gophone Fusion U8652 - Blue Smartphone Logo
A
Anonymous Posted on May 14, 2013
Reset touch screen calibration - Huawei At&t Fusion Prepaid Android Gophone Fusion U8652 - Blue Smartphone
Bizhub 500. made a mistake during touch screen calibration. Is there any option to enter the screen calibration without touching the touch screen?
Select the Accessibility button ?
Option (1) Touch Panel Adjustment - Touch the four "+" buttons ? Press Start ? Close
While calibrating the touch screen on my ricoh mpc 305sp I think I double taped on a wrong position on the screen and now touch screen isn't working properly. I know it still works as works in 1993 test...
I think you'll have to run a factory reset.
However, I cannot find any way of carrying this out. You'll need to contact Ricoh or their dealers, I'm afraid.
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
6helpful
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
HI MY MAGALLAN 1400 TOUCH SCREEN NOT FUNCTION HELP
If your touch screen does not function, do not panic, it is a minor problem, The solution the the problem is for you to either reset your gps device or you calibrate the screen. To reset the gps device,
  1. Turn it off and on,
  2. Then hold down the power button for about 15 seconds,
  3. It will restart itself automatically,
  4. Then the screen should be working now.
But if the screen does not still work, then you calibrate the screen. Calibrating the screen will do the job. But note, you need to calibrate repeatedly till the screen works.If calibrating repeatedly does not do the job, then you ave to seek a technician because it is no longer a software problem but a hardware problem.
Dec 24, 2010 • GPS
7helpful
3answers
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
3answers
The touch screen is not working. After resetting
If the buttons on the touch-panel LCD screen do not respond correctly or do not work at all, adjust the LCD screen calibration. Consult the instruction manual if specific information is required to perform this procedure.
NOTE: The touch-panel LCD screen cannot be calibrated if it is rotated.
21helpful
4answers
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
4helpful
2answers
China mobile
have a china made handheld double sim touch-screen phone. The device is Winkoy T6688. The touch screen got damaged and after reseting the device, the following notice appears after turning it on:
"Calibration wizard. You have to calibrate the touch-screen. Click anywhwere on the screen with your stylus to start calibration".
Of course you can´t but there´s no other option because it won´t accept any other input until it´s calibrated apparently. Does anyone know how to bypass this calibration wizard on start up?
Top Huawei Cell Phones Experts
NOEL
NOEL
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
