Question about Plustek OpticFilm 7200i Film Scanner
Computer I have just bought the above scanner. I have installed both cds. When I attempt to begin scanning, my computer tells me that it cannot find the scanner and/or make sure it is connected and switched on. I have tried and tried with no success. I was told that if I took off my other scanner it could work as XP gets confused!!! Have you any other suggestions please? Thanks
  • 3 more comments
  • brehaut Aug 17, 2007
    have tried it and nearly everything else including diconnecting our other scanner. It loads and is documented in device manager as being in working order. The icon at bottom right of screen shows red cross it. Looking in programs the icon is OK. So I really do not know what to do next.
    Any further suggestions would be very welcome.
    Thanks
    see above
  • brehaut Oct 04, 2007
    with a little bit of luck - found how to work it.
    Now 2000 slides later I am experiencing non responsive message more often than not. Even when I only have Page Manager on, there is no improvement. Has anyone any ideas?
    Thanks
    John
  • sarah_pal554 Jan 12, 2009
    This is the dumbest solution I ever heard of
  • jthedee Feb 14, 2009
    When I first tried to install my Plustek 7200 scanner, Windows XP recognized the unit and I was able to install the soft ware. Because I was not able to find my power adapter, I ordered a replacement and uninstalled the the software, intending to reinstall everything from scratch. Now, with the proper adapter, Windows XP will not recognize the unit and I am unable to install the installation software unless it recognizes the new hardware. I have followed the Quickstart intructions to the letter to no avail. Any answers????
  • 661 Answers
If the Scanner was plugged into the computer before the software was installed, the computer does not know what to make of the unknown device, (which it cannot identify). This is why it is recommended that the software is installed before connecting a camera scanner or printer. If you check in "Device manager" you may find unknown devices listed under "Other devices" if you remove these and then disconect and reconnect your scanner, it should then detect the scanner correctly.
Posted on Aug 14, 2007
  • Gareth Cockram
    Gareth Cockram Oct 04, 2007
    it is possible that the scanner is trying to draw too much current from your USB ports (when connected with everything else, Have you tried a powered USB hub (one with a plug top power supply)
SOURCE:
My scanner want scan
Re-install the software but do not connect the USB cable immediately. Begin the installation and let the software tell you when to re-connect the Usb Cable to the computer. Let it finish
Reboot computer and Windows will find it.
Or, go in control panel and click on Scanners and Cameras. You should see the Kodak icon there. Click it and scan from there. If the scanner was well installed, it should work from there as well.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Kodak Printer Support
Feb 26, 2014 | Kodak Esp 3250 All-in-one Inkjet Printer
How do i get my mustek 1200 iii ep flatbed scanner to work with windows xp. my computer restarts every time i clink on scan.
If you have the orginal software that came with your scaner and it says that it is compatible to Windows XP, you may need to use the disc to reinstall it. YOu will first need to turn off the scanner and unplug it from the PC. Then uninstall the old software from install/uninstall in your control panel. (start>control panel>install/uninstall programs, search the list for your scanner software.)
If you do not have the software or it is not for Windows XP:
There is the link to a site with a driver download specifically for your scanner, instructions on installing it for windows XP and also a link to answers to problems for your specific scanner.
http://www.mustek.com.tw/Download/driv_scanr/english/1200ub.html
Before you begin any download make sure your virus control software is up to date.
First click on the link "Instructions for XP installation and print it out.
Next click on a driver for XP from the chart to download it. When a window pops up click save and browse until you locate desktop. Save this file to your desktop. It will be an .exe file.
Turn off your scanner and unplug it from your PC and uninstall the oldsoftware as advised above.
Click on your new driver file to install it. Follow instructions.
Once the driver is installed, plug the scanner back into the computer and turn it on.
Restart your computer.
It should now recognize your scanner.
Try a scan.
Dec 18, 2010 | Mustek Plug-n-Scan 1200 III EP Flatbed...
I bought an HP Scanjet G4050 as recommended (by John Lewis?s) for use with my new Macbook Pro laptop bought at the same time. This was somewhat over a year ago, and I have used the scanner lightly, but...
Hi there, you are very near in the solution. Just today i solve the same problem manually. When the system ask this message "where I want the image saved " 1st select the path -- My computer/C:/program file/HP scan jet/ select here the Scanner Icon and press Ok. I mean just follow the location of installation file of your scanner. After that scan the image or else , you will get the success. Thanks & waiting for your success feedback.
Feb 18, 2010 | HP Office Equipment & Supplies
Attempt to scan, screen states
This error occurs because the HP scanner can not communicate with your computer and thus won't scan. In most cases this is simply because you don't have all of the necessary drivers installed.
  1. Insert the software CD into your CD ROM drive. The software installer should automatically start
  2. Install the software and restart your computer when prompted
  3. Try to Scan using the Scan To or Start Scan buttons on your printer
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | Computers & Internet
When I open HP Scan Pro and attempt to scan a document it tells me the scanner is not found. It is plugged in by USB correctly.
The computer is looking for a "Twain" device. Although the printer is correctly installed, to scan a document or picture, you need a program to associate with the scanner and identify the "Twain" device. To do this, open up any photo software or even MS Paint. Under the File tab there should be an option to Import or Import from a device i.e. camera, scanner. This is the option you want. Select your HP Scan Pro as the Twain device and you can scan from your computer. The other way would be to open HP Imaging software package that came with the machine and configure your scanner from within the program. Either way works its just a matter of preference. Best of luck and reply back with any questions.
Nov 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
KODAK ESP-3 AiO Will Not Scan On Vista 64 Bit Ulitmate
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
Feb 16, 2009 | Office Equipment & Supplies
Don't know how to scan
if the drivers for the scanner is installed then you can check in my computers - name of your scanner.if the drivers are not installed then you will not see a icon of your scanner. you can download the drivers from the manufacture website.plz post your findings
Jan 14, 2009 | Canon PIXMA MX310 All-In-One Printer
Will my acerscan 310P scanner work on my XP computer?
yes u can use the mira scan drivers for acer prisa 310p
which u can download by searching google !!
Jun 08, 2008 | AcerScan 310P Flatbed Scanner
Benq flatbed scanner error ffff;0024 will not operate or scan
This appears to be a software or communication between scanner and computer.
go for the usual re-installation of the software program being used, i.e paperport or similar.
try removing and reinstalling the scanner itself.
unplug the unit for between 30-60 minutes, to eliminate power pack overheating issues.
unplug the comms cable ( USB or other ) and re-connect.
Mike @ Compurepair.
Feb 19, 2008 | Office Equipment & Supplies
Computer does not recognise scanner
look on your cd (do a windows search function) for files named "...something.MSI". Right click on this file and select either the "INSTALL" or the "RUN" utility. this should force the driver install.
Aug 17, 2007 | Nikon Super Coolscan 5000 ED Film Scanner
Open Questions:
Plustek OpticFilm 7200i Film Scanner Logo
260 people viewed this question
Top Plustek Office Equipment & Supplies Experts
Thomas F. Schneider
john1959ny
john1959ny
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
