what wont my mp3 player turn on ? every time i do try to turn it on it either says key locked shut down and if i every do get to see anything else its the main display sansa disk but thats it i tried to chargeit to see if that helps but it does not what should i do ???
if it isn't the 'hold' switch then there is something wrong internally. if you wanna try...
sandisk ran me through these troubleshooting steps, hope they help. do one at a time and see if you get a result -Reset device take out battery hold power button for 30 count put battery back in turn device on.
-Upgrade firmware Go to website, download firmware update
Install according to instructions. let the device reboot.
-Format memory. turn hold switch on, orange should be visible hold pause/play button and press power. click forward button when the screen comes up. let this run. after reboot flip the hold switch off.
hi my problem is that my sansa blowed out.. there's only a sign " refreshind database".....
(More)
hi my problem is that my sansa blowed out.. there's only a sign " refreshind database".. fishing battery out doesn't work. anything doesn't work.. what could i do?
