Question about Jensen MP-5010K CD Player
Troubleshooting/Need manual/ Need remote/Hook up problems
I am having trouble getting the speakers to work. The receiver worked in a bench test, but when installed in my school bus with New speakers/no sound. I drive a school bus, and had another stereo previously, and worked fine. I have no idea how to program or de-program . I cannot find a manual, for my Jensen MP-5010K CD Player, nor a remote. Can you please help me?
NEED PLUG DIOG.LOST PLUG
Posted on Jun 25, 2008
6ya staff
SOURCE:
How do i fix a noise problem on 6.1 avr 135 ?same trouble occur on alls channels,a high frequency sound disturbing listening.neither inputsi used(cd-dvd-tape)
There are many reasons this may happen, but without having the unit on the bench, it will be hard to tell. It may be oscillating, which would make that sound. I worked as a Technical Support Specialist for Harman Kardon. If you are interested in repairing your HK, please visit my website at audioserviceclinic.com. Thank you.
Jan 10, 2015 | Harman Kardon Audio Players & Recorders
How do I get this system working properly again?
Here's what I would do:
1) Wherever you get sound, hook up each speaker in turn to validate they are working. If you have another, known working system to do this with, even better.
2) While testing your speakers on the known good system, once a speaker has been proven working, validate that your sound source (and cable) is working by using it as a source once everything else has been validated.
3) Now that you've isolated and proven everything but the receiver, put the receiver in stereo mode and try it out as a simple left/right amp. Once you get this far you will be able to do the surround stuff, but only with a surround encoded (ex: AC3) data stream.
If you need more help, just ask.
Graham Leach
Dec 16, 2014 | Audio Players & Recorders
DEH-P5800MP pioneer ...all things come up and operate except for sound out the speakers. Even the volume dial registers as well as the screen volume graphics.
Hi Michael,
We will start with the pdf manual. http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130P5200HD.PDF
Next you will check all the speaker connection's so they are biased +- +-. Ensure your ground is correct at the chassis of the receiver to the frame of the car.
Here is the manual from Manual Labs another look. Pioneer DEH P5200 Manual
There is a reset on the speaker output located in the manual. Perhaps your speaker impedance is above the receivers digital tolerance. Bench test the speakers with other in place of the working site. Most of all situations are oversights or happenings when closing up the job site.
Audio adjustments at your finger tips to check that by the book.
Pioneer DEH P4800MP Operation Manual Page 25 Using Balance Adjustment
And finally. Our site has a lot of answers. Please take some more time to familiarize your head with it. After doing some trouble shooting from a-Z check this out.
Troubleshooting Support for Pioneer DEH P5200 CD Player
Fare. Well.
Everyone please learn the ropes at Fix Ya. A lot of your answers may be posted. Please take patience into account for those who strive to prepare their sincere intentions to succeed.
Please? We want you to rock. Easy does it.
Jul 06, 2014 | Pioneer DEH-P5200 CD Player
I can only get the right half of the speakers to work, how do I get the rest?
switch the speaker connectors and see if the ones that work on the right work on the left. if they do then your amp is ok and the problem is either the wiring for the right side or the right side speakers. If the speakers don't work when you try this swap, then you have a bad channel onn your amp and will need a bench mechanic to fix it, (if you could find one). also make sure that you have a signal to both the right and the left, this can be tested by again doing a swap, take the left feed and put it in the side that is now working and if you hear sound then the inpurs are ok
Mar 17, 2011 | Denon AVR-1100 Receiver
I have a 37 inch sansui flat screen television model # HDLCD 3700. The sound just quit working; the picture is fine? Is thier any trouble shooting that can be done?
Please unplug TV from AC wall socket for couple of minutes, replug back in and turn it On and check sound.
If problem still exist, check internal speakers are enable / ON in Menu.
If speakers are ON and yet no sound, then need to check sound at Audio Out jacks at back of TV, hook audio cable (white-red rca pins) in audio out jack in TV and receiver/ amplifier to get TV sound in receiver/ amplifier speakers. This is a test/ check and you can use it to get TV sound through receiver speakers.
And if still no sound in audio out jacks in TV then TV needs main board replacement. Check with local TV repair shop for that.
Thanks.
Nov 15, 2009 | Televison & Video
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at [email protected] and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
Display indicates "Protection" and unit shuts down. What causes this and how can I correct? Will a shorted speaker cause this?
Yes, there are two ways to check this, either disconnect all the speakers at the speakers or do the same at the receiver. I would start at the receiver, this is the most common problem of all AV users. Disconnect all speakers (with the receiver off) then turn it on. If it does not go into protection it is either a wire or a speaker, the best way to troubleshoot this is to reconnect each speaker one by one making sure you don't have any excess braid hanging over the pins then turn on the receiver. repeat until the unit goes into protection or, you've solved the problem. If you find a speaker with a problem, if possible replace the speaker with a known working speaker and test again. If it still goes into protection, run a new speaker wire and test again. At this point if it is still going into protection, you may need to get it to a repair house or AV store, have them bench test the unit for you first, then if needed, send it out for repair. If you need any help at all during this, post a comment and I will help some more.
Jun 26, 2009 | Onkyo TX-8011 Receiver
Lost almost all sound in both speakers
Test the speakers on a bench if possible with a different receiver and some new wire. Or if you have a multimeter check the impedance, should be 8ohms if it's got a short, it will read 1..... or ....1 If the speaker wire when connected to the outdoor speaker is not siliconed, it acts as a wic and will oxidize the wiring and cause a short. do you have a separate volume control for them? and is that volume control indoor or outdoor? is it connected to a receiver or amplifier? The fastest test though would be to hook up the rock spkrs directly to another unit. If you still have trouble, reply and I will help you troubleshoot further. Hope this helps
May 24, 2009 | Insignia Simulated Rock Outdoor Speakers...
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
Can get either 1 or 2 speakers working at the same time.
u can't do use a 5 with a cox only with fiberoptic than it will work
Jan 12, 2008 | KLH R5100 Receiver
Jensen MP-5010K CD Player Logo
251 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
