Question about Olympus Camedia C-770 Digital Camera
Power switch not working in power off position
All of a sudden the power of my C770 UZ camera is not switchnig off. Unless the battry is removed, the camera stays in its on ( still/movie/play) position only. Can you please help. Thanks in advance
  • 12 more comments
  • Swamy Aug 14, 2007
    Thanks for the hint. Is trhere a way to do the repair ourselves?
  • Jinxer Jan 21, 2008
    I also cannot shut off my Olympus C770UZ. Swamy did u find a solution.
    Swamy did u find a solution for the shutting down issue in Olympus C770UZ?
  • Anonymous Feb 01, 2008
    I too Have the same problem, when i want to turn camera off, i have to pull battery out which might cause problem to the camra in future.
  • Anonymous Apr 01, 2008
    I use two Olympus 770's, one is my own and one at work. They were purchased about 6 months apart and both have developed this same problem within 2 months of each other! So far I just remove the batteries to turn them off
  • Anonymous May 26, 2008
    The power does not go off. The only way to make it go off is to remove the battery. Not a fun way to take pictures. :(
  • seabrkcall Jul 18, 2008
    How weird it is! I cannot get the camera to shut down. It will not change to playback mode or off although the power switch does move to both positions.I called tech support. Cost to repair is average $165 with Olympus. I haven't found anything more reasonable. Trade in value? $57.00 IF it's functioning properly. Seems better to purchase less expensive cameras now. I bought mine in "04. They've improved so many things, but this is as bad as buying new computers every few years. How very disappointing!
  • Anonymous Jul 24, 2008
  • darvybeckyfu Jul 27, 2008
    Power switch is not turning off
  • kordas Aug 24, 2008
    I have similar problem with the on/off switch, but worse ;) The camera
    does not switch into the picture mode (3rd from the left on the sliding
    switch), and the lense does not extend. I can turn it off and I can
    take movies.
    It seems to be a mechanical problem with the switch, which does not
    properly connect. The fault has developed without any "shock" to the
    Any ideas, beyond opening the case? (Costs of repair are above camera's value).
  • Colms Dec 28, 2008
    Camera will not power down and lens stays out when switch turned to off.
    Regards Colm
  • gr8fulbear Jan 08, 2009
    my problem is similar to kordas'. camera function will not work but the movie, still, and off functions work. any solutions other than opening the camera and tinkering around? perhaps the last time i buy an olympus.
  • 2,985 Answers
Well Not having taken one apart, I would not know or advise except to say it is probably like grand fathers watch You know having put is all back together after cleaning it sill does not go aright and what do you do with all the bits left over? Olympus customer support I would think is the best place to inquire- especially if is a youngish camera
Posted on Aug 14, 2007
Wont turn on after having brand new batteries put in
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using Fixya
Sep 06, 2011 | Olympus SP-510 UZ Digital Camera
What does 'write protect' mean; it is stopping me taking photos.
Hi,the memory card has a switch on it,its a protection for your files.Just power off then take out the memory card and look for a very small switch.Just move it to the unlock position.This should fix the problem,don't forget to rate....
Nov 17, 2010 | Olympus SP-510 UZ Digital Camera
Camera automatically asks to format or turn off. I just bought the XD memory card to use in my camera (OLYMPUS 550 UZ). I had the camera power on and proceeded to put the memory card in while the device...
Never insert or remove a card while the camera is on. You can try to download the pics on the card to your computer using a separate card reader. Then, format the card in the camera.
Mar 08, 2010 | Olympus SP-550 UZ Digital Camera
How do u retrieve photos that have been saved on camera(sp-550 uz)memory not a picture card
With the camera's power off, remove the memory card.
Turn on the camera's power.
Retrieve the photos, as you ordinarily would do, were the memory card still in the camera. If you have the USB cable connected, then you can move the photos to your PC's hard drive, using either the camera's software, or Windows Explorer.
Jan 22, 2010 | Olympus SP-550 UZ Digital Camera
Camera will not turn on. Already replaced batteries.
as per your camment you already replace the battry thats means no problem in battery Ok Firstly please follw the steps,remove memory card(if have),power resourses like AC power adaptor and batteries and wait some some just about 10 min,than reinsert the battrie and AC power adaptor,swith on the camera without memory card,if it is work and than insert ithe memory card otherwise reinsurt the memory card correctly and close the memory card door properly if the camera working fine other wise follw the third instuction that check the AC power supply,this is connect properly through input or not.connect the properly and turn on the camera and check issue is resolved
If you not find the solution thats means your camera has been damaged,need the service of camera and second resion is if you insert the battry incorrectly ,some issue
One more resion is images in memory card,firstly download ths images in system and formate the card.
Jan 16, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
When switched on, the screen goes straight to CARD SETUP highlighting POWER OFF, with the option FORMAT.If FORMAT is selected, a CARD ERROR screen is displayed, after the CAUTION ERASING ALL message. The...
This normally means that you have a faulty xD memory card.
With the power off, remove the card and try cleaning the contacts using a cotton bud (Q-Tip) moistened with a little rubbing alcohol. This is unlikely to solve your problem but costs nothing to try. If it doesn't work then you must try using another xD card and this usually fixes the fault.
If that fails, there is nothing more which you can do other than to consider sending the camera for repair, but you'll find that this is definitely uneconomical unless the camera still has warranty cover as a good used & fully functional example of your camera will cost less than the labour charges needed to fix yours.
To prevent the problem reoccurring it helps if you only ever wipe/reformat the card when it's in the camera: do not use an external card reader except for uploading images.
I hope that you have found my posting to be of some use and ask only that you return the favour by rating my answer.
Oct 23, 2009 | Olympus SP-510 UZ Digital Camera
Sony DAV-C770 Red Light Flashing but nothing is on!
power supply or power amplifire unit problem.give it to repair proffesional.
Jan 19, 2009 | Sony DAV-C770 System
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Olympus Camedia C-770 Digital Camera Logo
498 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
