Question about Grandstream Handytone 496 Dual FXS Adapter SIP VoIP A (HTATA496)
My grandstream 101 voip phone
I was using a Grandstream 101 voip phone when accidentally using a power supply having 9 volts DC. Its power is actually 5 volts. The internal program of the phone is working ok and could reset itself. The problem now, it could not anymore link with the D-LINK router which is connected to the internet. Upon examination of its board the maximum voltage of the capacitors were 16volts. There was no burn parts observed. What do you think is the problem. Other Grandstream model used with this router has no problem at all. Lixberto
5 Suggested Answers
SOURCE: grandstream password recovery
if you have a password reset disk use that.otherwise
you must use the password recovery software
Posted on Feb 16, 2008
  • 3 Answers
SOURCE: my ip phone doesn't works
Replace your power cable and you problem will be solved.
Dawit
Posted on Nov 16, 2008
SOURCE: Secret block
Access Denied
Posted on Jul 21, 2010
  • 23 Answers
SOURCE: does grandstream gxp 280 support vonage
Yes it supports.
SIP Account Name: Vonage
Phone Number: xxxxxxxxxx (enter your Vonage phone number)
Authentication ID: xxxxxxxxxx (enter your Vonage phone number)
Authentication Password: xxxxxxxx (enter your Vonage Authentication Password, this can be Provided to you by Vonage. Please remember that the password is case sensitive.)
SIP Domain: leave blank
Proxy Address: sphone.vopr.vonage.net
Port: 5061
Outbound Proxy: sphone.vopr.vonage.net
Port: 5061
Local Port: 5061
Register Timer: 3600
Codec: Auto
Pkt. Time: Default
Out of Band DTMF: On
-Karthik.
Posted on Oct 20, 2012
I have a Grandstream GXV3175 with a cracked screen. Can I get it repaired? How much will it cost.
It will be more cost effective to buy a new unit plus you will have warranty also on it.
Mar 17, 2015 | Grandstream Lands Phones
How do I unlock grandstream 1405 keypad
Press '*' Star for more than 4 sec then it will show the password to input if you have put it or simply press OK.
May 30, 2014 | Grandstream GXP-1405
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
Does grandstream gxp 280 support vonage
Yes it supports.
Port: 5061
Port: 5061
Local Port: 5061
Codec: Auto
Pkt. Time: Default
-Karthik.
Sep 25, 2012 | Grandstream GXP-280 IP Phone
Bridge computer to grandstream (for phone power)
I have the same problem Did you get an answer. Verizon wants I should talk to there expertise tech for a fee. Did anyone try it?
Jan 31, 2009 | Lands Phones
Grandstream budget tone 200
Go to internet
Type your the ip phone address
type admin as password if you never changed it
That's it
Nov 04, 2008 | Grandstream GXP-2000 IP Phone
Grandstream password recovery
Feb 14, 2008 | Grandstream GXP-2000 IP Phone
Grandstream Handytone 496 Dual FXS Adapter SIP VoIP A (HTATA496) Logo
105 people viewed this question
Top Grandstream Computers & Internet Experts
Alun Cox
k24674
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
