Question about Philips 20PT6441 20" TV
21PT3324/71 Philips TV wont stay on
TV set needs to be warmed up before it will on continuously. Then it has now the problem that it will on for about 8seconds then will off automatically. you need to turn it on using the remote control. I did some resoldering thinking that it is just a cold solder but nothing happens. here is the voltage measurement: Filter cap = 298 Vdc Collector of Horizontal out Trans = 35Vdc What are the readings supposed to be? What approach can I do to troubleshoot my TV? Thanks in advance.
  • bashlort Oct 28, 2007
    Hi Mike,
    I can't adjust both the brightness and contrast to 0 because before I can access the menu settings in my set it will shut down. But I have managed to put the TV set in service default mode and its error blinks corresponds to high beam current and black loop instability.
    I adjust the screen voltage and see the retrace line and back down the screen voltage, but still no joy, my tv is still shutting down. Thanks for your advise. BTW, my TV set is just 1.5 yrs old. I'm just dissappointed that after it broke down 6months after its warranty.
  • 398 Answers
Try this: On the flyback transformer, raise the SCREEN voltage. There are 2 controld on the flyback - the top one is FOCUS and the bottom one is SCREEN. As the tube ages its emission decreases, and the computer monitors the tube's emission. When the emission gets to be too low, the computer shuts the set down. This is exactly like IK blanking in Sony sets, except Sony blanks the video and Philips shuts the set off. To set the screen voltage properly, turn the brightness and contrast to 0, raise the screen voltage until you see the white retrace lines in the picture, and then back down on the screen voltage until just past the point where the retrace lines are gone. Reset your brightness and contrast and the set should play fine.
Posted on Aug 14, 2007
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
Green light continues to blink
These blinks are fault indications, called blinking codes. To count the blinking codes to Philips brand Televisions are some what different. It cannot be counted directly. If you wish to get more details about how to count the blinking codes, and convert it into fault codes, check the site linked here. It is very difficult to type in all here by this window. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 09, 2013 | Philips 32PT6441/37 32" TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
TV wont stay on longer than 15 minutes
Sounds like your power board is shutting down as it gets hot. I would get prices for and replace the power board!
Mar 18, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
RCA modelD52W20 Problems turning TV on when it is cold or for the first time after being off for an extended amount of time. The green lite comes on ,stays on a few seconds and goes out. After continueing...
well usually what works for me is a small heater on near the tv or just keeping the room above 65 degrees. There is a way on some tv's to turn off the power saver and that will keep your tv warm. But on others you cant turn it off so you have to deal with the heater or keeping the room warm cause that tv wont turn on for anything exept if its warm....
Dec 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv
How mant times the the led on the front of the set blinks? And how long do it stay on before it goes out?
Aug 20, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv turns on and off by itself
Picture tubes rarely go bad. You have a bad connection or something on the circuit board that is breaking down due to the temperature change . Probably an easy fix. Not something an unqualified person can do though. Your local shop should fix this for about $60-100.
Jul 17, 2008 | Philips 25PS40S 25" TV
Color has too much red
Is this happening when you are switching between color tempature (Normal,Warm, and Cool). You wont be able to access it in normal menu.
You will have to accesss the service tech menu. enter "062596 then info", if u enter the code correct at bottom of screen you will see a warning menu only access by a service tech , continue in menu you will see on main option screen "alignment" enter this. Go to white point adjust the three temp settings (Normal, Warm, and Cool) settings as follows.
Color Temp. I Red I Green I Blue I
Cool 122 120 121
Normal 125 118 108
Warm 127 110 75
( These are factory specs u can tweak them to your own perference)
After u set these press left on remote and exit back to main service menu and store these setting before turning TV off set these settings
I see this alot when Philips manufactured the TV. The did store the settings.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Philips 20PT6441 20" TV Logo
403 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
