Question about ViewSonic VX2235wm LCD Monitor
Blue Resolution Box
A blue box keeps coming up on my Viewsonic VX2235wm LCD monitor telling me that for best results use a resolution of 1650X1050. I have already used Control Panel on Windows Vista to make this setting. How can I turn off this reminder?
  • Anonymous Oct 16, 2008
    I followed the steps and everything worked until I tried to disable the notice and I was only able to check and uncheck the box. Neither solved my problem.
  • jabush Jan 03, 2009
    The 'blue box' pops up stating the options for resolution choices....have found nothing to stop it - comes up during startup.
  • 3 Answers
To turn off the reminder, use the buttons on the front of the monitor to do the following:- Press #1. Use down arrow to highlight Setup Menu and press #2. Use down arrow to highlight Resolution Notice and press #2. Select Disable and Exit.
Posted on Aug 13, 2007
Suddenly the resolution changes and monitor messages come up. Cannot get it to adjust.
That means the PC video resolution got changed some how in the PC.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
This model is also know to have bad DC filter caps which more likley to go bad soon.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Please leave rating if it helps.
Mar 01, 2011 | ViewSonic VX2235wm LCD Monitor
I am attempting to use a Viewsonic VX2235wm 22 inch LCD monitor with my Alienware m11x Rx2 laptop. (4g DDR3, Core i3 520um, Windows 7 64-bit) as an extension ofn my desktop. Naturally I would like to use...
Does it do the same if you hook it up to the desk top PC?
Common problem in this VX series are due to bad DC filter caps which can cause a lot of starnge symptom, see pictures here:
The power supply may not be stable enough to handle higher resolution mode.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | ViewSonic VX2235WM Monitor
I cannot install the driver for Viewsonic VX2235wm (XP pro) Cannot select 1680x1050 res for this monitor
Well your LCD supports 1680x1050 resolution.
You have to check the video/ graphics card of your PC, if it supports the same resolution or not. Let me know the model no. and your motherboard details for a better assistance.
Looking forward for your response
CreativeTECH
Nov 13, 2010 | ViewSonic VX2235WM Monitor
I need to change my montior to 96 dpi what does it mean and how????? please help
I do not know who tell you to adjust the monitor to xx DPI. First of all, you do not adjust the resolution at the monitor, the resolution adjustment is done at the PC video setting, your monitor has native resolution of 1680 x 1050 with refresh rate set to 60Hz. DPI spec is usually for printer resolution capability.
Jan 08, 2010 | ViewSonic VX2235wm LCD Monitor
I have a va2223wm monitor out of the box..and trying to install. it is giving me an error that says out of range. what do i do?
Start the computer with the monitor attached. It should discover a plug and play monitor and adjust the resolution to a setting that your monitor accepts. If it doesn't, boot the computer with your old monitor, go to screen preferences, choose advanced, monitor, and change the monitor type (driver) to Plug and Play monitor. Now do what I suggested above.
Oct 27, 2009 | ViewSonic VX2235wm LCD Monitor
Out of range
Your windows video settings are for a monitor that has more capability (eg more pixels/finer resolution, higher refresh rate, more colour bits than the current screen can handle so it's spit the dummy.
Run your computer in safe mode (I believe that uses basic video driver) and set the video display options to a very low level, then re-start your computer again in normal mode, and set the options to the native resolution, refresh rate etc of the monitor. These should be listed in the specs that would come in the box with it (may be resolution: 1,680x1,050)
Sep 13, 2009 | ViewSonic VX2235wm LCD Monitor
Hi i have big problem with my ViewSonic VX2235wm monitor
check did you insert external display card or using internal if not inserted then internal display card will not support above 600x800 if you want to work with high resolution then insert AGP card and reinstall drivers there are 4 type cards 1x,2x,4xand 8x you use 8x AGP card then select high resolution also you can look best movie and good support to 3D games
Nov 18, 2008 | ViewSonic VX2235WM Monitor
Cannot get correct resolution
1. It could be limitation of your video card. Older cards would not support high resolution for LCD monitors.
2. Be sure to use DVI(digital) output from your video card. You will not get a good resolution with VGA(analog)
3. When installing driver for a monitor sometimes you will get a chose to install analog(VGA) or digital(DVI) driver. Choose the correct driver.
Jun 04, 2008 | ViewSonic VX2235WM Monitor
Monitor resolution
when you increase considerable resolution windows will ask you do you want to keep these settings? you select yes then that will be saved
Feb 15, 2008 | ViewSonic VX2235WM Monitor
Benq monitor fp51g
What's the owner's manual say that means?
Jan 13, 2007 | BenQ FP51G 15" LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
223 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
