Ceiling fan approx 15 years old. only label is ''encon'' hanging on chain. no model number is shown any where I can see. picked model number below because it was listed first.
trying to replace with harbor breeze fan switch. need to know wire placement of 4 wires, black, purple, yellow, red in relationship with L, 1, 2, 3.
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
SOURCE: Remote fans quit working during a thunderstorm-lots of lightning
I've been having the same problem with my remote not working. I actually just checked the dipswitches in the remote against the ones in the ceiling fan, and they somehow were not the same. It seems that the 4th dipswitch may have inadvertently been altered due to the battery either being changed or just moving. I advise you all check out the settings on the actual fan to see whether or not they match up.
Twist the cap covering the wiring above the fan (make sure the power is off, just in case), and you will see a black box like thing straddled towards the top. There is a little rubber square cap guarding the dipswitches. Take that off and note the setting of the 4 switches (on/off). Compare it with the remote by taking the batter pack off and looking at the 4 switches there.
I noticed that the 4th switch on my remote was turned on when it should have been off. I changed it back, and now it works.
Hopefully this helps you all.
SOURCE: I need a spare parts for a Harbor Breeze remote
Where can I purchase a capacitor for harbor breeze
SOURCE: Replacing a pull switch on an Encon fan. 4 wires.
Where can I buy a 4 wire ceiling fan 3 speed switch (red-blue-orange-black) 0183m 17292101 Have no idea what brand it is. probably about 15-20 years old. Wires are labeled A-B-C-D.
