Question about Denon AVR-900 Receiver
Denon AVR 900
The front Left and front Right speakers of my denon AVR 900 are working fine... The center/woofer/ and back left/right are not working at all. I was given the receiver by my brother and I don't have the manual or the remote... How do I activate the other speakers? Jeff
Well its possible you have it on stereomode put it on prologic ceneter mode on normal for best sound
Posted on Nov 05, 2008
You need to put the volume up on those speakers you can only do that with the romete s you kinda stuffed unless you get the remote.
Posted on Oct 04, 2008
LOST LEFT FRONT SPEAKER AND CENTER SPEAKER
Check all connections and the balance settings. (Left / right/centre) If these are ok, the output system on the amp has probably failed. Denon are a good unit. See if there is an Agent or Amp specialist nearby that you can take it to.
Sep 17, 2015 | Denon AVR-5805 Receiver
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
I recently purchased a new Denon AVR-391 receiver and am having a problem hooking up my subwoofer. It seems that the Denon has a pre-out RCA looking output and my subwoofer uses conventional speaker wire. ...
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
IN A SUB-WOOFER, IT CAN CANCEL OUT THE LOW NOTES.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
Mark
"Phase Cancellation"
Jan 05, 2011 | Audio Players & Recorders
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
Denon AVR 600 Subwoofer Test
Can you explain about your system problem in detail.
So that it will easy for us to offer you better solution.
Dec 03, 2017 | Denon AVR-600 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
No Sound Right Front Speaker
Sounds (forgive the pun) like that channel's power chip is gone. Take it to a Tech, I may advise...
Mar 29, 2017 | Audio Players & Recorders
609 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
