Question about Motorola Mobility SLVR L7 Cellular Phone
Motorola SLVR won't sync with iTunes. HELP.
Every time i connect my phone to the computer, iTunes reads that my phone and at first, it says that it's synced. Then, when i drag a song into my phone, a message pops up saying that this mobile phone could not be synced and that my disc could not be read. PLEASE HELP. This is driving me nuts!
    Brigadier General:
  • 7,752 Answers
Hopefully it is converted to .mp3 then try again
Posted on Jun 04, 2008
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Please tell me that where i found motorola slvr l7 pc suite
first Instal motorola phone tools
And then Go to Ur Phone Menu and then to settings
Find for connectivity
Set their Data/Fax
Then connect ur phone to computer
May 09, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Phone Tools Installation Question
you need to install the MPT-Mobile Phone Tools software then connect the USB cable and you your phone.
Jun 03, 2008 | Motorola Mobility SLVR L7 Cellular Phone
ITunes on my phone
well get the firmware reflash on the phone and next time when u connect it to the pc via usb cable you will remove it the correct way.....take the phone to a mobile service center and have them reflash it for a small fee.
Feb 05, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Itunes problem
Had the same issue and my phone was under warranty. Sent it back and got a new phone, but the problem continued. Turned out, the memory card was bad. Nothing wrong with the phone. Try using a different memory card (card is in a slot on the right side of the phone, next to the keypad) and see if that works.
Jan 16, 2008 | Motorola Mobility SLVR L7 Cellular Phone
SLvr Phone Itunes
reformat the card then try again.
try master reset and clear the phone, then try again
Nov 20, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Arthur378
the problem with the slvr is iTunes gets in the way when you connect it to your laptop or PC. You need to turn off iTunes in order to connect to the Motorola Phone tools that is installed on your system. If your Phone did not come with motophone tools then buy it at this web site or ask for it at the cell phone store you got your slvr.
http://direct.motorola.com/ens/MPT/MPT_Home.asp
Nov 12, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Slvr L7 Memory Card Problem
I know for a fact that the slvr l7 will support 1 gb due to the fact that my slvr currently has a 1g sandisk card in it that functions perfectly
Oct 05, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola slzr iTunes
Disconnect the USB cable from your Motorola phone featuring iTunes, Wait 10 seconds & Reconnect the USB cable to the phone (it will confirm the connection with a tone). Again Wait 10 seconds, then open iSync and try syncing again. If the issue continues, turn your Motorola phone featuring iTunes off and then back on. Then open iSync and try syncing again.
Oct 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Downloading problem
I am pretty sure you need to use Itunes software, because Windows Media Player is not a compatible software Itunes. So I suggest you use these instructions: 1. Install Itunes on you computer via the disk that came with your phone or via internet on the Itunes website. 2. Transfer all of your music to Itunes( it is pretty easy) when Itunes is installed a window should pop up stating if you would like Itunes to import all music. ( IF NO WINDOW POPS UP THEN DO IT THIS WAY) 2b.While Itunes is open follow this procedure click File Scroll to Import or Add Folder to Library Select folder Click OK Repeat till all music upload this will take a bit longer , but you can now be able to use your phone.
Aug 15, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
176 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
