Question about Compaq FP 7020 17" Flat Panel LCD Monitor
Power supply cord
How common is it to be able to find a power supply cord for this type of monitor? Compaq 7020 LCD Monitor 17" .... unfortunately, i'm not computer savy. can it work with sony pc tower?
  • macker4279 Aug 27, 2008
    i need a power supply lead
  • Anonymous Mar 25, 2014
    I recently purchased 2 elo 1520l monitors but they came with no power supply cords.... where can I find one?
  • 3 Answers
Yes it is possible to get the product from HP(as now compaq is owned by HP). The part number of the product is 259055-001. You can ask for this product from HP by calling them at 1-800-227-8164. They may also give you a better alternative part number for the power cord. But according to me this particular part would be best for you monitor(259055-001). You can also buy this product online from hp.com. Yes in fact you can use sony pc tower to display on this monitor.
Posted on Aug 13, 2007
6ya staff
SOURCE:
Monitor not powering up
Hi
Try the power cable.Could've been blown.
Switch it with the CPU'S and see what happens.
Mar 02, 2012 | Compaq FP 7020 17" Flat Panel LCD Monitor
I had a Compaq FP 7020 (Carbon, Silver) 17 in. Flat Panel LCD Monitor with power green led on but no video . I tried to connect to different known good boot desktops , problem sill existed . What component...
It sounds like the screen is bad. A quick search with the model number and "LCD Screen" will show you that it would be cheaper to purchase a new monitor.
If it was the back light it would be an easier repair. But you are saying it does not come on at all so that is telling me the screen itself is bad.
Hope this helps! Please rate my answer :) Thanks!
Jun 12, 2011 | Compaq FP 7020 17" Flat Panel LCD Monitor
Compaq 1720 monitor: the green light on the power supply went away, the voltage converter was very hot and the monitor went blank
You need to find out if the power supply is still putting out 12vdc, you may have to test it with a load (use 12v car bulb such as the brake lamp). It is getting hot can be due to bad power supply or too much load because of short circuits in the monitor. Please post back what you find about the power supply first.
http://www.unitedsale.com/AC-adapter-Power-Cord-Charger-12V-35A-For-Compaq-1720-LCD-Monitor-Brand-New_p_219.html
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 03, 2010 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Wont work
Please make sure to check the following: 1- Hook up a different monitor to make sure that the video card on your PC is working properly. Also set it to a low resolution
2- Ensure that the power supply cord has a good solid connection with the adapter (if you have one) and the wall outlet 3- Make sure your monitor is on (some have more than one ON button) 4- Make sure that the data cord between your computer and the monitor has a good connection
Apr 24, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
Compaq Monitor 7020 adjusting...
Try monitor on another PC / laptop, if still no go it will be either faulty cable or monitor.If it works then the video card is faulty or needs to be reset in the slot.....you haven't said if its a PC / laptop.
its pc not laptop,but when i use other monitor for that pc it works
Jan 24, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
How to fix black stripe on left side of monitor?
The black stripe is there because the connections to those pixel rows inside the lcd panel are interrupted. This is unfixable. Buy a new monitor.
Oct 30, 2009 | Compaq FP 7020 17" Flat Panel LCD Monitor
OSD LOCKED in Compaq LCD 17" Model No. 7020
I had this problem with a different model. try this.
. turn off the monitor.
. press and hold the Menu key while you turn on the monitor again.
Jul 21, 2008 | Compaq FP 7020 17" Flat Panel LCD Monitor
Removing the case for a Compaq 7020 17 in LCD monitor
The case has 2 plastic snaps en each side as well as 3 snaps at the top
Use a flat-head screwdriver in the **** between the gray and black plastic. Twist the gray plastic away from the black plastic, and this will snap the part appart
Apr 24, 2008 | Compaq FP 7020 17" Flat Panel LCD Monitor
Compaq FP 7020 17" Flat Panel LCD Monitor Logo
210 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
