Question about Motorola Mobility RAZR V3
All the keys except the call end key froze
All the keys except the "call end key" on my phone froze.. tried to turn off and on several times but in vain...
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Sounds like a glitch in the "flash" program. Visit your local wireless providers store to see if they will "update the flash" for you. If they won't, then contact Motorola directly. They are very good about warranty and will most likely overnight you a replacement. Best regards, torgo
Posted on Aug 13, 2007
SOURCE:
2001 pt cruiser the ignition key lock froze up and I replaced the car turned over several times then stopped trying to start again I replaced the key lock again still no start what can it be?
Could be the immobiliser. The ignition key usually contains a transponder that should be coded to match the security code in the car's memory.
Replacing the key usually means using dedicated equipment to code the new key. I suggest you take advice from the dealer or a local auto locksmith.
Jan 25, 2018 | Cars & Trucks
Tried the steering wheel and key at same time still wont turn
Tap the lock cylinder with the handle end of a league screwdriver with the key removed. You can be faily agressive when you do this. Then insert the key and try to turn. Try this several times. If it finally does turn replace the lock cylinder immediately. The key needs to be in the run position in order for the lock cylinder to come out. If you can't get it to turn the lock cylinder will need to be drilled out.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Aug 01, 2012 | 2001 GMC Jimmy
2001 ford taurus key won't turn ignition
The steering wheel was turned when the key was removed. So when you try to turn on the key, turn the wheel one way and the other way to release the pressure on the key. The key should turn ok.
Hope this helps.
Jul 29, 2012 | 2001 Ford Taurus
Phone just froze cant press any of the keys or anything. tried to turn off and turn back on but still nothing
I have the same phone. It does this to me all the time. I suspect that it is just a general problem. I end up taking the battery out for a few minutes and then restarting the phone. Usually after that it's fine again. This doesn't cure the problem forever, meaning that it will happen again, but next time just quickly remove the battery and restart. Hope this helps.
Dec 12, 2009 | Motorola Mobility W385 Cellular Phone
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Oct 19, 2009 | Panasonic KX-T7633 Corded Phone
Clock on Phone
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jun 24, 2009 | Panasonic KX-T7633 Corded Phone
Messaging lock down
perform a master reset on your phone the defalt pass is 6 zeros:000000 then try to access your txt msging you phone will return to defalt settings and make sur you turn your phone off once in a while for the updates service providers send that you dont know about not turning your phone off makes them do wierd things
Feb 16, 2008 | Motorola Mobility RAZR V3
Frozen buttons except red end call button
it seems you have the common v3 keypad flex problem - normal issue - it costs $25-40 to replace depending where you do it.
we charge $25 + shipping
http://horizonwirelessonline.com
Dec 25, 2007 | Motorola Mobility Razor Behind-the-Head...
Motorola Mobility RAZR V3 Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
