Red dwarf peak and edmund in the lion the witch and the wardrobe
Look for a strange rock. Once you've found it, play the panpipes to see a
red magical note, which will reveal a statue [1]. In front of this statue
there is another one [2]. Keep on walking until you reach the frozen lake.
Here go left and hit the small frozen waterfall until you destroy it. Have
Lucy go through the hole to reveal a statue with a platform above, which
contains a shield (1) and a statue [3], and then have Lucy return to where
the rest of the children are.
To the right and downwards there is a statue [4]. Then have Peter hit the
tree to the right. After your halfway done some dwarves will appear. Switch
to Susan and shoot them. Go back to Peter and keep on hitting the tree to
destroy it, and then proceed to the next area.
-o- Checkpoint -o-
A scene will start, and once it's finished you'll encounter more Ghouls.
First I must warn you of the eagle; it will drop rocks into the ice that
will not only hit you, but may create a hole in the ice (if you fall through
it you will lose).
Down and to the right is a statue [5], and in the center (also in the lower
part) is a shield (2). Go to the middle of this area and play the panpipes
to reveal two notes. One will yield a shield (3), while the other will make
the enemies fall asleep. There's a dwarf in the back, which you should kill,
and then shoot the barrels to its right to get a shield (4). To the right of
those barrels is a statue [6]. On the ice and a bit to the back is the last
statue in this area [7]. Now go to the tree trunk that's blocking the path
and Team Up Lucy with Susan to destroy the ice blocks on its front. Then
have Peter destroy it.
-o- Checkpoint -o-
As is usual, a scene will be triggered. Before actually fighting, there are
some new upgrades available. Susan's Fast Reload and Peter's Lion's Claw are
very effective during fights.
Start off by switching to Susan and shooting the rocks to the left of the
Ogres. The rocks will fall and take out the Ogres. If you can manage to hit
the rocks to the right of the Ogres you will be able to block the path that
the Boggles are using, but it is slightly difficult to actually aim at them.
Anyway, if you feel the need, you can play Susan's panpipes in the center
of this area to sleep all of the enemies.
Go down and shoot the barrels to obtain a shield (5). Switch to Peter and
hit the tree trunk blocking the path until it sets on fire. Have Susan throw
snowballs at it (She'll throw them if she is aiming at the tree trunk,
instead of shooting arrows). Then switch back to Peter and continue hitting
the tree.
An Ogre will eventually surface. The best thing to do is to play the
panpipes to make all of the enemies fall asleep, and then deal with the
tree trunk to the right until you destroy it.
-o- Checkpoint -o-
A scene will start. It appears that a sledge is chasing you, and the counter
on the upper part of the screen shows how much time you have left. It's
impossible to fall from this piece of ice that you are on, so you can kill
the Ghouls without worrying. Hit the statue that's up [8], and once you kill
all of the Ghouls a piece of ice will float to the right, connecting where
you are with the area to the right. Switch to Lucy and have her connect the
blue sections of ice in the new area, until she has created a continuous
path.
-o- Checkpoint -o-
Kill more Ghouls. Remember to grab the timers that give you more time. In
the upper part you'll find two statues [9, 10]. Once the Ghouls stop
appearing a piece of ice will float to the right, and you'll have to use
Lucy again to find all of the blue sections of ice.
-o- Checkpoint -o-
Here you'll encounter a lot of enemies, including Minoboars for the first
time. Hit the statue that's up [11], and the one that's down [13]. Then use
Susan to shoot the barrels on the platform with the dwarves to obtain a
Shield (6). After this, play your panpipes in the lower area to reveal a
magical note that gives you a shield (7). Once you kill all of the enemies
you will finish the level.
II.09 - The Great River
First of all, use Susan to destroy the explosive barrels, so that you don't
get hurt. Then play the horn (same as the panpipes) to reveal a magical
note that contains a shield (1). Now go all the way to the left to find two
statues [1, 2]; you'll have to get there by walking where the ice isn't
Dec 04, 2008 |
Buena Vista Games Chronicles of Narnia:...
