Question about RCA P46924 46" Rear Projection Television
Phillips 60'' hdtv wont turn on
My hdtv wont turn on at all (remote or tv itself. It has never " not" turned on yet. We unplugged it, plugged in into several different outlets.. and no dice. --RC
    Novelist:
    Scholar:
  • 149 Answers
It sounds like its had it. Sometimes it might mean a bad powercord or that the powercord went out on you. Is your set DLP or is it just regular CRT rear projection? If its DLP or DILA/LcoS you should check to see if the lamp has imploded. Good luck. p.s. you can always check the batteries in the remote to :) maybe they need to be replaced?
Posted on Sep 13, 2007
How do I fix a 40" seiki tv to turn on
try the power button on the TV itself somewhere on right or left side
Jan 31, 2015 | SEIKI Digital SE40FY19 40" LED TV...
LG 42" Plasma - remote wouldn't turn off TV, nor
unplug for a couple of hours. the tv holds charge and bleeds off electricity very slowly.
Mar 22, 2011 | LG 42PG20 42 in. Plasma HDTV
I own an Emerson 37inch tv modelnumber EWL3706 AND SERIAL NUMBER J33615468 LAST NITE THE VOLUME WAS AT 26 AND ALL BY ITS SELF WENT TO 60 IT WONT GO DOWN NOT WITH REMOTE OR ON TV ITSELF I UNPLUGED IT AND...
Hello! Your tv controls the volume if it jumps up to 60 after moving down it may be interference with the TV's remote sensor. Has anything changed i.e. new lighting ? Try calling Emerson at: 8002562487
Daniel Busa
DISH Network Customer Service
Jan 14, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Turned off by itself and never came back what part will I replace
If the TV is completly non-responsive (ie not even a flicker of light on the power button) then one of the first things to check on this is the fuses - easiest being the right corner next to where the power cord plugs in (have to take off the back panel)
May 30, 2009 | Philips 60PP9202 60" Rear Projection...
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
Phillips 60'' projection hdtv wont turn on
Question do you see green led or light when pressing power button? If you can also listen for a high pitch noise coming from back of set. This would be an indication that the set has powersuppy problem or high voltage problems. If the set is dead and no noise then maybe fuse or open circuit.
Aug 13, 2007 | RCA P46924 46" Rear Projection Television
RCA P46924 46" Rear Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
