Question about Onkyo TX-DS787 Receiver
I cannot find the internal backup battery.
Hi there, I have read a similar problem posted by Bugsey but i have checked the boards with the fuses but still cannot locate the internal battery, any ideas thoughts. Does anyone know what type of battery i am looking for size shape etc. Thanks again.
  • thecraw Sep 30, 2008
    Thanks guys for you're help, as explained i will just reset my settings when they lost usually during storms /power outages etc.
    New Friend:
I ran into the same issue with my Onkyo 787 receiver that the internal settings would get reset after a short power off. Getting all settings entered again (preferences, speaker distances, volumes, stations, etc.) is a real pain. Good news is that Onkyo DOES have a battery (actually a capacitor) to store the settings and that capacitor can go bad. Another good news is that replacement is quite easy.
The settings are preserved by a 5.5V 0.1F capacitor. Digikey sells it for around $1.50, you may choose a higher capacitance, as 0.3F if you're replacing it. I didn't want to wait for the part, so I decided to replace with something I had around from an old power supply. I used 10V 1000uF capacitor as a replacement and it works fine. Yes, it is 100x less in capacitance, but preserving setting for a short time is better than not preserving them at all. Settings survived a couple of days disconnect and I haven't tried leaving the receiver off for any longer yet.
Here's how you can find it: it's on the main horizontal board, on the same side where the volume control is. It's small, looks like a watch battery turned on the edge. Mine was in a blue shrink wrap. I cut off the leads next to the battery and left the wires sticking out of the PCB. There's plenty of room to put any capacitor.
Pixonian
Posted on Sep 29, 2011
    New Friend:
I believe it is c906 on the Harmon Kardon 500 series receiver's "Tuner/Front Panel board". It is a .1F (note the lack of a 'u' in front of that F) 5.5v capacitor that feeds into the 5v power of the main chip.
Posted on Jan 06, 2013
  • David Mcanulty Jan 06, 2013
    For some reason when you search google for avr500 battery you got this page
Hi Craw,
Did you find the battery pack? If so where did you get replacements. I'm about to change mine out.
Thanks,
Bugsey
Posted on Sep 20, 2008
  • Anonymous Sep 30, 2008
    Yeah, that's what most of us have been doing but when you live in an area with frequent power outages, it's a real pain in the A--.
    Bugsey
On a TX-DS787 receiver there are no backup batteries for memory preservation.
There is a chip, probably a c-mos chip on the circuit board.
Mine erases memory during lightning storms.
Easiest way to fix is write down all your settings and reprogram when it goes dead.
Posted on Sep 29, 2008
6ya staff
SOURCE:
Ups mge galaxy 3000 G3K
If you cannot do a reset of the internal fuse system and get it operational, then check the internal battery for continuity. If they all fail, then the AC/DC transformer has blowen.
Mar 15, 2014 | MGE UPS Galaxy 3000 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
My bnt 500 does not come on backup, when supply fails output drops to zero.Battery seems ok giving 11.8 wils. These volts dont increase on charging state.Is charging ckt ok. thanks for help. maslam
Check for open Fuses first of all. Test the battery again on load not just with Multimeter. You can use a 10Kw potentiometer resistor or a 80W Car head lamp as the load on battery and see if the voltage still reads 11.8V for the first 30 second. If the Voltage drops rapidly and there are no open fuses, replace the battery. Alternatively contact a local technician for troubleshooting on the Board.
Jun 08, 2010 | InterAct Accessories Powercom Black Knight...
Replaced ipaq 4150 internal backup battery but
read the manual yet, or lost it> or?
most of these have 2 batteries
one that pops out one more that solders down.
guess which one retrains data.
finding parts for relics like this is not fun
what good is this thing besides, wall art?
why ask here at all, we are not HP , nor are there HP books here.
so ask here.
there are folks there that might remember so long ago
or even have old books laying about after all they are HP.
https://h30434.www3.hp.com/
Dec 10, 2017 | HP iPAQ H4150 Pocket PC
No ac in
there be an internal fuse or reset button on or close to circuit board, you'll have to open it up to get at curcuit board, make sure you have power at wall receptical, cord isn't bad, unplug when you open it, be safe
Jul 08, 2009 | APC Back-UPSĀ® CS 500 UPS System
Burnt out
internal failure possibly on power side, lower than 300A fault current so unit could not trip i/p protection and as fault was post ac section, continued to burn internally.
it just broke
no breakers tripped out so it kept drawing current until the fault burnt away.
maybe this is what happened, need to know a lot more info to change hypothisis
Jun 01, 2009 | Vector VEC056D 2500 Watt Power Inverter...
Doesnt power on
On some UPS you have to hold the power button down for 5-10 seconds before it switches on.
May 29, 2008 | Monster Cable MP-HT-UPS-1000 (ht ups 1000)...
Symbol RF MC9060S - Internal Battery is dead
You have to first charge the backup battery, for charging insert a fully charged main battery into the MC906x. Then the backup battery will starts charging leave it there for one day. if that message is still coming then the problem is with the backup battery and u have to replce it
Jul 06, 2007 | Laser Symbol Technologies MC9060S Mobile...
How to repair UPS
my ups got sound is what proplem
Jun 02, 2007 | APC Back-UPS CS 500VA UPS System
Onkyo TX-DS787 Receiver Logo
947 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
