Question about Sony DVDirect VRD-MC3 DVD Recorder
Failed to record
Used sony dvd+rw dual layer and memorex dvd-r single Using DV in from my canon elura 100 to dv in on the sony The machine begins to record then after 10 minutes it just stops and the screen displays "failed to record" "remove disc." I thought that the buffer amount of video was too great so I reedited my video tape and shortened the tape to about 40 minutes. The same thing happened. I don't want to keep buying discs by trial and error, or is there any other things to try?
  • pHNN Dec 03, 2007
    Was able to burn DVDs. Now fails after 35 mins. Tried using different media and brands: no help. Seem to have been able to get a full recording by turning *off* autochapter feature and *then* creating a single chapter point 2-3 mins into the burn. Go figure
  • Nathanroo Dec 26, 2007
    "Failed to record. Remove the disc." I have a Sony Digital HandyCam I am trying to use with the DVDirect, trying to burn onto DVD+RW discs, and I consistently get the Failed to Record error. I have tried taking off autochapter, PC Use / Not Use, quality settings, etc. Is there something I am missing? Figured the two devices ought to be compatible, both being Sony. Thanks - if I find a solution independently, I will try to come back to answer my own question. Thanks
Need to connect both the 3-prong AV adapter *and* the firewire cord. The firewire connect alone does not work, and the 3-prong AV cord alone does not work. But connect both cords to the two devices, and it seems to work. 15 minutes and counting... Hope this helps someone.
Posted on Dec 26, 2007
The DVD Burner will not burn a Memorex DVD - R . Should I purchase Verbatum or Memorex for an older model MSI DVD Burner? Or, Should I purchase Verbatum or Memorex for an older model Samsung TS H652...
You are on the right track. Every "multi-format" DVD recorder, DVD burner and DVD-RW drive I have ever owned has had problems with one type of media or another. This is because the discs all have their own patented dye mixtures, and each is a little bit different.
I have problems using Memorex DVD-R discs on my Toshiba DVD recorder. The only drive I can get good results with Memorex DVD-R's is on my Memorex DVD drive.
For DVD-R media, I have had the best success with TDK DVD-R's.So far, they have worked on all my devices.
You may want to try DVD+R media. I use Memorex Lightscribe DVD+R and for dual layer recording, I use Ativa DVD+R DL discs, both of which have worked very well and I rarely have to throw one away.
It takes allot longer, but on my PC I always use the "verify" function to make sure I get a good copy.
Feb 17, 2011 | Samsung TS-H653F DVD±RW Dual Layer Burner
I am using an old, borrowed Canon NTSC Elura 100 camcorder with a Mini DV 60 tape. I do not have the original Picture Package software or the manual, and I am trying to transfer onto my computer, which...
You can download the manual, software, and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/elura_100
Dec 12, 2010 | Canon Elura 100 Mini DV Digital Camcorder
How to burn dual layer dvd with windows dvd maker only 150 minutes pie showing
Everything is the same except you have to choose "DVD-R 9.0G" at the bottom of the DVD maker window. R4.5G is single layer and 9.0G is dual layer.
Let me know if you need more help,
Sai.
Apr 02, 2009 | ASUS P5GZ-MX Motherboard
LET ME KNOW THE PRICE OF PIONEER DV-610AV-S DVD
The price of the DV-610AV-S is about US$140.
Source: http://www.google.com/products?q=DV-610AV-S
Mar 21, 2009 | Pioneer DVR-610A (012563011843) DVD RW...
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Finalize Error
You can not retrive unfinalised disk because no path was put into place to read the information that was burnt. Data yeap was burnt but way of reading it was put into place.
Mar 25, 2008 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Export movie from an older TRV68 to computer
I purchased a canon elura 100. The 100 has a AV -> DV converter. This allow you to tunnel your Sony via a 3.5mm 4-pole mini AV to mini AV camcorder A/V cable to your computer.
Sony (via AV out) -> (AV) Canon -> PC/Mac (DV) via fire wire cable
Feb 12, 2008 | Sony Handycam CCD-TRV68 Camcorder
Burning multiple mini dvd's to one dvd
if you have a pc and a video editing programme, you can make the 3 dvds into one by adding them individually as chapters directly from your camera. The programme i use is nero recode, you can download a trial version of this if you have no video editing programme. http://www.nero.com/nerodigital/enu/download.php
May 07, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Open Questions:
See all Sony DVDirect VRD-MC3 DVD Recorder Questions
Sony DVDirect  VRD-MC3 DVD Recorder Logo
249 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
