Question about Kenmore 24902 Top Load Washer
Kenmore 80 series
Washer filled started then stopped. Won't move in any cycle. Sounds like the timer....is it hard to change out, could I possibly do it myself? If so, is there a site to coach me thru it. As a now single mom I am on a tight budget.
  • 1 more comment
  • bufordwon Mar 18, 2008
    This is a "dual agitation". The bottom part agitates but the top just sits there
  • Anonymous Apr 05, 2008
    when I use prewash mode, the clothes will end up soaked at the end of the cycle. It doesn't seem to be spinning fast enough to get rid of most of the water. Can you help me out?
  • kmquillen Apr 09, 2008
    The washer filled up and then stopped. it won't go to the next cycle. Is it maybe something wrong with the agitater?
  • 5,911 Answers
If your washer fills normally, but then stops, this is usually an indication of a defective lid switch. If you raise and lower the lid, you should hear a "click" as the lid closes. No "click", bad lid switch. This is a typical problem for this model washer, and it is not hard to replace. A lid switch normally runs about $34. A timer, on the other hand, can run as much as $200 depending on model. In either case, you will need to remove the console to replace by following these steps: 1. Unplug the washer. 2. Remove console. Depending on the model you have, there are two ways to remove. a. The first type involves removing the two end caps to expose a screw. The end cap has a groove in the back at the top that you can place a flat tip screwdriver and gently lift. The cap should pop off. Loosen the screw under each end cap and grasp each end of the console. Pull slightly towards you and lift up. The console will flip back to a resting position over the back plate of the cabinet. Be careful not to damage the plastic hinges that hold it in place. b. The second type involves placing a putty knife under each front corner of the console and pushing straight from the front to release a retaining clip on each end. Push in with the putty knife while gently lifting at the same time. The console will pop up and can be placed in the resting position as mentioned in the previous step. Again, be careful not to damage the small plastic hinges that hold the console on. Now if you're going to replace the timer, this is as far as you need to go. However, if you need to replace the lid switch you will need to go a few steps further. 1. After the console is removed, disconnect the the white connector plug on top of the washer casing. This is your lid switch connector. 2. Next, remove the two brass colored clips that hold the case to the frame. Place a flat blade screwdriver in the groove on the clip in the opening on top of the washer casing and push away from you. This will release the clips. 3. With the lid open, grasp the casing from under the front rim where it goes into the wash tub. DO NOT grab the wash tub itself, just the case. Pull from the back first and lift the case off the frame. The lid switch is located under the right hand side of the lid opening on most of these washers. Some, will be located in the back. Just remove the plug, two screws, and a ground wire and that's it. 4. Install new switch in the reverse order of the steps given. 5. Placing the case back on the frame can be tricky, but it's not hard. Looking down through the lid opening of the washer, make sure you place the front lip of the case UNDER the frame. Then, carefully lower the case from front to back ensuring you get the small cleats on the frame into the slots in the casing. There are four slots that need to be seated properly in order for the frame the stay on and not vibrate. Seat the front, first, then the back. 6. Place the brass colored clips back in place by hooking one end into the slot on the back plate of the washer first, then pushing down into the opening on top of the washer. The clip should snap back into place if you have it correctly seated on the frame. You will have to push down with a little force. 7. After that, reinstall the console and you're done. Now...an easy way to check to see if you have a lid switch problem is to take the connector that leads to the console and find something to short the two black wires together with. DO NOT cut the plug to do this. You will have to use alligator clips or a piece of insulated wire and insert into the plug. Do this with the washer turned off and unplugged. Once you have successfully jumpered the two black wires, plug the unit back in and start the washer. Allow to fill on a small load size. If the unit fills then begins to agitate, you know you have a bad lid switch. Stop the washer by pushing the timer button back in and unplugging. The lid will not stop the washer at this point, because you have by-passed the switch. If the washer still has the same symptoms then you may be right with your guess that you have a bad timer. In the majority of the machines I've worked on, however, the lid switch will fail first. It might be worth a try to replace the switch first, before spending a lot on a timer you may not need. Let me know if this helps.
Posted on Aug 13, 2007
SOURCE:
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't change cycles
yes check the lid switch timer
Jul 17, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Washer won't cycle
Sarah, it sure could be the timer. If you start a cycle, it fills, starts agitating but the timer does not advance after that, it's probabley the timer motor. You want to make sure that this is happening on all cycles and cycle speeds. Have someone pull off the consol end caps, (they just pull off) remove the two screws and flip the consol up. Make sure the harness to the timer is seated. The part number for your timer is. 8557393. Catriver..post back.
Feb 10, 2007 | Kenmore 15864/15862 Top Load Washer
Kenmore 24902 Top Load Washer Logo
144 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
