Question about Maytag SAV5701A Top Load Washer
Washer won't work after the lid came off and was put back on
The lid was wrenched off the washer by one of my kids. I put the ball bearings back on the corners and slid it back into place-- no big deal. However, now the machine won't work at all... with the exception of about five minutes of spinning on only one of the cycles. What in the world could be wrong? I've checked the water supply, circuit breaker and everything else that came to mind. Help please... my kids have the stomach flu! Gross!
  • 641 Answers
It sound like a lid switch issue. The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. Look if it is not broken, moved from its place or has a lose wire. If it's defective, it should be replaced. Be aware you should plug out washer's power cable first ! Good luck!
Posted on Aug 13, 2007
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Can i use my washing machine with no lid switch
as long as everything is working it's ok,all it is is a safety switch so the washer won't run with the lid open,a kid could open the lid when it's spinning and it won't shut down and if the kid sticks his or her hand or arm inside it could get ugly so it's a safety switch that's it.
Feb 22, 2012 | Kenmore Washing Machines
Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Jan 05, 2012 | Hoover Washing Machines
Water remains in the dishwasher
Hello.
There are several reasons that a washing machine,or dishwasher won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
1 A dishwasher won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
3 Loose or broken belts could also prevent a dishwasher from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4 Another possibility for a dishwasher to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5 If all of the above steps fail to produce a dishwasher that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thanks.
Oct 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin out water but pump works
1.A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
2.If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.3.Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4.Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5.If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thank you for using FixYa and please don't forget to rate me.
thanks,
Reymond
Oct 18, 2011 | Maytag Washing Machines
Spin cycle doesn't work.
Hello.
Here are names of tools and instruction below to solve theproblem
  • Screwdrivers,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop
There are several reasons that a washing machine won't drainor spin. The cause could be something as easy as a clog or something difficultthat will need a licensed repairman. Start with the simplest possible cause andwork down to the more difficult causes. ·1A washing machine won't spin if the water can't drain. Check hoses for anykinks or clogs that may prevent the water from draining. If a hose has kinks,try to straighten out the kinked hose. If it can't be straighten sufficiently,replace the hose. If hoses are not kinked, check for clogged hoses. This can bedone by using the screwdrivers to remove the hoses and looking for clogs orrunning a water hose through the clogged hose to remove the clog. Use the ragsand bucket to clean up the water that comes out of the hoses when they are disconnected.Once the clog is cleared, put the drain hose back into place. The washer shoulddrain and spin now if a clogged or kinked hose was the problem. ·2 If the washer still won't drain or spin, checkto see if the lid is not closing all the way or if the lid switch is notclicking into place. Close the lid and make sure that it closes all the waydown. When the lid closes, the lid switch should click. If there is no clickingsound, then the switch may need to be replaced. Follow manufacturer's directionsfor replacing the switch. If the lid does not close all the way, visually checkfor signs that the lid is bent. If bent, try to bend it back into place. ·3 Loose or broken belts could also prevent awashing machine from draining or spinning. Pull the washer away from the walland, using the screwdrivers and wrenches, remove the back panel. Using theflashlight, visually check for any broken or loose belts. Replace any broken orloose belts. Although replacing washing machine belts is difficult, anyone whohas replaced belts on a car, lawn mower or even a bicycle chain should be ableto accomplish the task. ·4 Another possibility for a washing machine tonot spin or drain is the pump. With the back panel still off the washer, checkthe pump with the voltmeter to ensure that the pump is getting power. If thewasher is getting power, turn on the washer and listen to find out if the pumpis running but the water is still not draining. It may be necessary to removethe pump and clean it or to replace the pump with a new one. Once the pump isreplaced, turn on the washer to determine if it will now drain and spin. ·5 If all of the above steps fail to produce awashing machine that drains or spins, then it is time to call a professionalrepairman. Use the screwdrivers and wrenches to replace the panel on the washerand push it back against the wall.Thanks for using fixya.
Sep 06, 2011 | Maytag Neptune Washer
Candy washing machine not spining , cutting out med cycle and finally not drainig i dont know what to do
Hello.
Challenging Instructions And Things You'll Need:
  • Screwdriver,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop.
  1. A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
please rate this if this help?.
Sep 03, 2011 | Washing Machines
Frididaire washer error 10 Washer will take in water but doesn't spin or complete cycle. Doesn't let water out.
Hello.
When Washing Machines electronic control has detected a condition then it indicate by showinh error code which needs to check. When you see a code, follow these steps to solve the problem.
However, there are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
· Screwdriver,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop.
Aug 02, 2011 | Washing Machines
Machine is stuck on 23 and wont drain a small amount of water. it attempts to run. It is on the wash cycle. No error codes
There are several reasons that a washing machine won't drain or spin. The causecould be something as easy as a clog or something difficult that will need alicensed repairman. Start with the simplest possible cause and work down to themore difficult causes.
ChallengingInstructions And Things You'll Need:
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall..
Thanks and thanks for visit good luck.
Jul 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Roper washer agitator won't spin after kids loaded
It sounds like a someone has broke the lid switch to the washer. Below I have attached a picture, Item number 9 would be the part you seek. P# 3949247 Under the control panel you will find a harness that contains 3 wires coming out of the cabinet housing. The colors should be tan, white and green. If you jump the white and tan you unit should run and think the lid switch is working. Safety way is to unplug the unit to by-pass the switch and plug it back in and select spin only. This is only to test, you need a lid switch for safety. You should replace it ASAP if this test works for you.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Roper RAX4232KQ Top Load Washer
Maytag SAV5701A Top Load Washer Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
