Question about Canon BJC 6100 InkJet Printer
Color blue won't print
I have a BJC2010 (I don't print very often)my printer would not print blue and red. I took it out and soaked in hot water as someone else suggested. Well it worked for the red that is fine now, but the blue still won't work correctly. It comes out a blueish tan. I have tryed new ink and alot of maintance. Help. Shali
  • 56 Answers
Replace the color cartridge. inkjet ink doesnt last very long if not used regularly. soaking rarely works very well try replacing the cartridge. or simply replace the printer. this is actually usually cheaper than replacing both cartridges.
Posted on Aug 16, 2007
My printer only prints magenta\
A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced
This may help
You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink.
For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode.
If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode.
If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink.
For more Help Source... Can You Fix Dry Ink Cartridge eHow
Thanks,
HP Phone Number
Jun 25, 2014 | HP Officejet Pro L7680 All-In-One InkJet...
I replaced the black ink and the error light is on and the out of black ink light is still on. Won't print
Try it.......
Remove the print head and soak it for three 5-minute cycles in hot (~170 F) distilled water about 3/4 inch deep with continuous mild agitation. The first soak quickly turn the water black, the second end with the water a dark grey color. The hot distilled water dissolved the dried ink in the small ink passages from the cartridges to the ink ejection part of the print head.
Carefully dry the print head as per instructions, clean the electrical contacts on the printer, and placed the print head and the ink cartridges in the printer.Turn off the printer, then unplugged it for one minute.Then turn it on...and print an alignment sheet...
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 20, 2012 | Dell 1320c Laser Printer
Pro901 stopped printing in color
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 16, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Dell photo AIO 966 printer wont print red color
Sep 23, 2012 | Dell 966 All-In-One InkJet Printer
My epson stylus color 400 will not print in black...I have replaced the two ink cartridges...if I type in color it prints in color...if I type with black ink...it does not print...please help
I had the same problem.
Solution: The black don't print in standard resolution (regular paper)
Set your printer in higher quality paper and your black will print.
This is another problem with Epson nx 415..................
Good luck !!
Mar 03, 2011 | Epson Stylus NX400 InkJet Printer
I have installed new printer cartridge (Colour) and it is only printing blue. Cartridge is identical to the old one which printed OK.
I found this procedure hard to believe, but my 710C was printing black and pink only. Someone suggested taking the color cartridge and soaking the tip in hot water! I microwaved some water in a cup for 2 minutes, placed the end of the color cartridge in it for 30 minutes. I took it out and blotted with a paper towel until finally all three colors bled out. I dried throughly and put back in printer.... it works great. I might also add I had 2 new cartridges that this happened to.
Jan 12, 2011 | HP DeskJet 895cxi InkJet Printer
Black #16 wont print I just refilled cart. only prints in red
If your printer isn't rejecting the cartridge then it sounds like the print head is clogged. You can try to get it flowing again by rubbing/soaking the print head on a paper towel soaked with warm water. When it is flowing it should give a thick black line when pressed into a dry paper towel. You could also try running a nozzle cleaning cycle on your printer. The red you're seeing is the color that is added during black printing to make you use up your color cartridge when you aren't printing color. Fun fact huh?
Jan 22, 2010 | Lexmark Z600 InkJet Printer
Prints in blue and green ; all ink cartridges are
Dear Dahcota; If it has a single color cartridge, there are three components inside the cartridge-red, green, blue, and all colors are a superimposition of these 3 basic colours RGB in different proportions. It looks like the red component has run dry. So, what you get is the color without the red component. If its showing all cartridges as being full, sometimes these levels shown are inaccurate. Try changing the entire color cartrigde or red component, then see if you still have the same problem. What I am not sure is if the red cartridge is a separate entity . If the red is separate, and changing it does not improve things, the connection in the printer might be faulty. Go to www.hp.com and browse for the correct make ask them online there, It should really be okay, once you have replaced the red or entire color cartridge is it is a single unit with all 3 colours
Oct 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
New color cartridge won't print in correct color
Was this a new factory ink cartridge or a refilled one?
I have seen some reconditioned/refilled with the color inks refilled in the
wrong section.
Sep 25, 2008 | HP DeskJet 812c InkJet Printer
Problem with colors in Canon i850
OK this is the tricky part. You will have to take your printhead out of the machine (the peice of plastic the cartridges sit in). It just has a single arm holding it in and nothing else. There a few things you can try I will list them in order of safest to least safe.
1. Leave the cartridges in the head (even if you have to hold them in with your hand) and use a thin head on a decent vacuum cleaner (preferably one that can handle wet and dry so you don't get ink everywhere) on the bottom of the head where the ink comes out. You may be able to suck the ink through effectively removing any blockages.
2. You can leave it to soak in Isopropyl alcohol or windex or really hot water (not boiling) and it may remove any blockages. You must make sure that it is completely dry before reinstalling it though or you will wreck the head.
3. Using a jeweller's ring cleaner sit your printhead in an inch of water and activate it for 60 seconds (This can also damage your printhead).
You can get an idea how successful you have been each time by dabbing the bottom (where the ink comes out) onto paper towel or a tissue. You should see 4 lines, black, cyan (blue), magenta (red) and yellow.
If all of this fails you may need a new printhead which is dearer then a new machine.
Good Luck.
Please rate my advice, good or bad.
Feb 07, 2008 | Canon i850 InkJet Photo Printer
Canon BJC 6100 InkJet Printer Logo
82 people viewed this question
Clive
Clive
old marine
old marine
