Question about JVC AV-48WP30 48" Rear Projection Television
Is this a convergence problem?
I just got this TV from someone and they said it needs the convergence fixed. The screen looks like a sideways hourglass with the 3 different colors in different portions of the screen. When I go to the convergence adjustment in the menu, the crosses are all way off. It will not respond to the commands on the menu and will not let me adjust it or even get out of the convergence menu. I have to wait for the menu to time out to clear. Every other feature on the menu works but the convergence. Can you tell me exactly what I need to do to fix this? Is this something I can do myself or will I need to have it done by a tech? Thanks for your help.
  • frediggy Aug 14, 2007
    Thanks for the help. I am not sure where these are or what they look like. Do you know of any drawings that I can get that will show me these parts? Also, do you know where I can find these parts?
    Genius:
  • 1,153 Answers
This sounds like not only convergence but also bad resistors on the convergence board. There are several resistors in the convergence area, I would change the convergence amps and have the resistors replaced. Look for burnt resistor or just colored differently than the others. check also for loose connections. you can tap on safely converg. board and see if problem changes.
Posted on Aug 13, 2007
How do I find thepico fuse on the tv what does it
22 is an error code for convergence...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2010 | Mitsubishi WT-42311 42" Rear Projection...
The lower half of my screen appears uncoded .at times the picture in this area at the bottom half is ghosting and has double images. does this sound like a problem that can be fixed or someone has seen....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2010 | Toshiba 62MX195 62" HDTV
MANUAL CONVERGANCE R56W28 ZENIETH
You have to use the remote - goto your convergence menu. If you can't adjust it - its broke - and needs to be fixed...
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
Apr 01, 2010 | Televison & Video
Same problem as above, picture bowed top and bottom, convergence
Projection sets have two very common problems outlined below.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
bb0cf99.pngSOLUTION
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
Philips 60pp9100d/37 convergence issues
Did you replace the 6.8 ohm 1watt resistors? As that model will usually blow a couple when the ICs fail.
Apr 21, 2009 | Televison & Video
Converjence Chip
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 07, 2009 | JVC AV-56WP74 56" Rear Projection...
Red sideways hourglass
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Jul 20, 2008 | Philips 60PW9363 60" Rear Projection...
PHILLIPS BIG SCREEN TV IS BUTTERFLIED
Are the colors out of alignment and unable to converge back? If so its the convergence ICs need replacing. If the convergence isnt out of alignment you have whats called a pincushion problem. If you would like a link to where you can obtain the service manual for this model let me know.
Mar 17, 2008 | Televison & Video
Color is warped and wrong
A convergence amp has failed. Very common. Plan on just replacing both STK modules (big flat circuit modules mounted on a big heat sink) with upgraded parts. Good ones cost about $40 each. Then readjust the convergence. Total cost at a shop is $250-$400.
Hope Ya Fix It.
Feb 07, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Convergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 23, 2007 | Toshiba 50H72 50" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
140 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
