Question about Toshiba TP55H60 55" Rear Projection Television
My 1999 TOSHIBA TP55H60 picture is not clear.
The picture on my Toshiba is not clear and has shadows from another channel. The cable inputs are very loose so I am thinking that is the problem. I plugged another tv into the same cable lines and the picture on the other tv is crystal clear. Let me know if you agree or if there is another path I should take.
  • 58 Answers
When is this happen? almost 8yr old the unit. In this case did u change the lamp bafore? Its seems that the lamp is dying. Try to use a DVD as ur imput and post here if it had a diff.? Use Audio/Video input instead of Coax (Cable). Hope this may help you
Posted on Aug 13, 2007
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
The power lamp flashes when turned on, no picture???
Ur tv needed a new lamp.Ur current tv lamp,in the tv now.U used the tv about 4 or 5 hours a day.Like the last 1 1/2 or 2 years the tv in used?The lamp life span is over.
May 14, 2010 | Toshiba TP55H60 55" Rear Projection...
ON-LINE INSTRUCTIONS???
One of the most recognizable makers of TVs in the world is Toshiba. The company's TVs are found in every major electronics store at a reasonable price. Packed with features, they have a model for everyone, whether it be LCD or older, tube-based CRT technology. Toshiba T.v are fairly easy to operate. Basic functions
  • Before you do anything with your Toshiba TV, you have to plug it in to a wall outlet. After plugging it in, locate the power button on the front (or on the remote) and turn on your TV. Depending on if you have cable TV or not, you can use the channel functions to flip between your favorite channels. The "Menu" button is useful to access advanced settings, like channel detection, parental controls, closed captions and picture controls.
  • Using video inputs
  • You can connect a variety of devices to your Toshiba TV via its front, side or rear inputs. If you look at the back, you'll see a variety of audio and video inputs to connect virtually any kind of device. You should see a few kinds of video inputs: Composite and s-video (for connecting older technology like VCRs and cable boxes), component video (for connecting older DVD players) and HDMI (for connecting digital technology like receivers and Blu-Ray players). Audio inputs are analog (red and white) or digital (coaxial and optical). Use digital connections when possible to ensure the best quality.
    To connect VCRs and DVD players, simply connect the proper cable to their audio and video outputs, then match the cable to the proper inputs on the back of the TV. Make sure everything is secure and take note of which input you connected it to. Now, tune your TV to the proper input by pressing "Video" on the remote.
  • Maintenence and tips
  • Your Toshiba TV is a sensitive electronic device, so precautions should be taken to keep it in top working order. If the screen gets dusty, wipe it with a dry, soft cloth. If you own a Toshiba plasma TV, be aware of burn-in and ghosting problems. Avoid watching programs that have static images is left on the TV for hours at a time. If you have a flat-panel Toshiba TV, consider getting it professionally calibrated to get the best possible picture
  • Dec 02, 2009 | Cell Phones
    I have a toshiba tp55h60, power light is flashing
    I have the parts you need if interested. Email me at hill6399 at yahoo.
    Oct 30, 2009 | Toshiba TP55H60 55" Rear Projection...
    Picture has a "wave" along the sides
    I have the parts, very cheap. hill6399 at yahoo.
    May 21, 2009 | Toshiba TP55H60 55" Rear Projection...
    Tobshiba tv stays in one channel.
    You might need to go into the menu options and set the input from cable to air or vice a verse. The tv in my kids room is like that if it's set to cable with no input at the cable jack then it only gets one channel even after you try to add channels.
    Dec 06, 2008 | Toshiba 36A50 36" TV
    Toshiba TP55h60 55in television
    contact rca or hitachi for a sub screen.
    Sep 10, 2007 | Toshiba TP55H60 55" Rear Projection...
    Toshiba TP55H60 55" Rear Projection Television Logo
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
