Question about Sony KDF-E60A20 60 in. LCD HDTV
Red Power Light Blinking 6 Times
My Sony 60" kdf-e60a20 doesn't seem to want to turn on. All I see is the power light blinking 6 times. Any suggestions?
  • jetsfan153 Jan 24, 2008
    I've had a Sony KDF55WF655 TV for about 2.5 yrs now and just last week I was watching TV and the picture just went out. When I turn the TV on now I get 6 blinking red lights. I've tried to self diagnose this problem, but I'm not positive of the exact problem. Doing some research I found that the 6 blinking lights means LOW B OCP/OVP (Overcurrent/over voltage). Is this diagnosis correct and if so is it something that I would be able to fix myself or do I new a professional? Also, is this an expensive fix or a minor problem? I consider myself handy, but I'm no expert. Any advice would be appreciated. Thanks.
  • MVAS Jun 10, 2008
    Red light blinks 6 times and continues to blink 6 times for several minutes after the power switch is pushed. Letting the set sit and reapplying power does not help. Any suggestions you have would be appreciated.
  • 4 Answers
THIS IS HOW I FIX MY SONY TV WITH FIVE BLINKING RED POWER LIGHT.
PULL OUT LAMP - FIND THE INSTRUCTION ON LINE (SONY WEBSITE OR YOUTUBE) EASY
THERE ARE TWO METAL CONNECTION TABS (on top of the lamp) ON THE LAMP. CLEAN THESE TWO METAL FLAT TABS. THESE two tabs MAKE CONNECTION TO THE THERMAL FUSE. IF IT IS DIRTY IT WILL NOT MAKE CONNECTION to the fuse.
CLEAN YOU'RE LAMP WITH A VACUUM. GET ALL DUST OUT.. CLEAN OUT THE TV...THE FAN SUCKS IN DIRT. THIS WILL FIX many ISSUEs. like over heating! dog hair, dust, gets sucked inside the TV by the FAN....hmmmm
ALSO DO THIS TO ALL YOU'RE ELECTRONICS THAT HAS A FAN.
(I FEEL ALL FANS ON ELECTRONICS SHOULD BE REVERSED) but i am sure there is a stupid reason that they want the fan to **** air inside the electronics. Like hmm
THIS cleaning SHOULD BE DONE EVERY 6 MONTH
Posted on Dec 23, 2010
Just had mine fixed it was the thermal fuse and was $200 to fix.
Posted on Feb 06, 2008
    Genius:
  • 1,153 Answers
AK-blinking it's called I believe. Shutdown because there are several parts that needs changing. Caps and resistors. Needs professional tech to do the job.
Posted on Aug 22, 2007
The unit turns on and off every 40 sec. or so. I have turned the unit off and on and I get a red light blicking 5 times on and off. this happened about 4 to 6 mo. ago and it is happening again...
Below info are related to Sony KDF-E60A20 lcd projection tv.
5 times red light blinking indicates problem with lamp drive circuit (ballast supply board) that is not producing high voltage for lamp to generate high bright white light.
Check/ replace ballast supply board in above mode tv to solve this problem.
If you tv model is different, let me know to provide you related info.
Thanks
Jan 17, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
Sony kdf e60a20 red lamp lights blinking
I do know it is important to know how many times the red light blinks.
Nov 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Tv blinks 6 red blinks
Thermal Fuse kit needs replacement = part # 1-910-023-93
Qualified tech only.....T.
Jun 22, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Kdf-e60a20
do a google, Sony 4 red blinking lights, there is lots to read. Read it all. We had 6 blinking lights and it was at $20 thermal fuse that we reinstalled ourselves and saved lots. It was past warranty. You can also put a message out on the blogs. But do your homework, it's worth it. Good Luck, Kim
May 20, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
I need help to fix my Sony KDF E60A20
Check the thermal fuse part# 1-910-006-44. You can verify this by jumping the fuse and the lamp should come on (it is located under the lamp)
Aug 28, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Red Light Flashing 6x
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
May 07, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
521 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
