Question about HP iPAQ H2210 Pocket PC
Ipaq h2210 won't sync with desktop
My PDA was syncing @ one time and I was able to sync my Calendar and contacts and such. I recently installed Office with Outlook and it won't sync the calendar or the contacts. I have tried numerous things mentioned in the activesync help, but nothing works. What can I do?
    Novelist:
    Scholar:
  • 114 Answers
Usually the simplest solution with Microsoft software such as active-sync is to uninstall it and install it again from scratch. When you reinstall it will ask you what programs you want to sync with, your old PIM software has been lowered in priority in favour of Outlook because MS think everyone should want to use it, so it's often easier to start using Outlook as your main PIM.
Posted on Sep 02, 2007
SOURCE:
Sync Iphone with outlook
just install itunes and you can sync calendar and contact to your iphone. You cannot sync the notes and tasks but. I have just bought an iphone and before I was using an HP ipaq like you. Everything is synced except for the notes and tasks. You cannot even see any word or excel files you had on your ipaq. Cheers
Aug 21, 2008 | Apple iPhone Smartphone
Won't sync from iPAQ to PC
Sounds like you've got the ActiveSync setting for the Calendar set to one-way from computer to PDA, not Synchronise, which means the computer will always over-write anything it finds on the PDA that isn't in the computer. Try uninstalling/reinstalling ActiveSync, and pay particular attention to all the settings when you reconnect the PDA and it sets up the connection - from memory at this point you can define the "direction" of synchronisation.
Aug 03, 2008 | HP iPAQ rx5915
Outlook
Check the setting on the ipaq, go to ActiveSync and tools, options, server and make sure calendar, contacts and inbox are not selected here. Then, put the pda in its cradle and let it do a sync, it should change the settings on the desktop and the (sync status on device) should disappear. I had a similar problem and after de-selecting these, everything worked fine.
Aug 21, 2007 | HP iPAQ RX3715 Pocket PC
Ipaq 2215 reset itself to orig. factory settings. How to recovery my settings and data
if you didn't perform backup on the pda before it happened, there is nowhere you can restore your settings from, try to sync with your pc, if you did it before, you must be able to get your contacts back
Aug 20, 2007 | HP iPAQ H2210 Pocket PC
Calendar and outlook sync
Is ActiveSync set to sync only items from the last 2 weeks?
May 22, 2007 | HP iPAQ H2210 Pocket PC
Sync problem
I assume you use activesync. Check in the options that it is set to synchronise this data. if you have already done this try reinstalling activesync or installing the newest version, 4.0.
Sep 15, 2005 | Dell Axim X3 Pocket PC
Sync problem
I am assuming you use activesync. Check in the options that it is set to synchronise this data. If you have already done this try reinstalling activesync or installing the newest version, 4.0.
Sync Doubling Calendar & Contacts in Outlook 2002
your t5 is UNSTABLE possibly due syncing to an old username from an old PDA. To correct this: -delete manually the doubles (PDS has a tool but none for outlook) -perform hard reset on your t5 -hotsync - creating a new user name (do not use the old one) -you will be asked to use the same profile name for the outlook Then you should be good to go.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Reinstallation of app onto iPAQ upon hard reset
In activesync under Tools/Add REmove programs you can check the box and click "ok" that will install the program. For the most part it's best to do it one program at a time. Obviously your PDA should be cradled or this. Most programs will re-install fine this way. Some programs though do require you to re-install from the installtion program directly since active sync doesn't pick up some important parts of the program. The two programs I have that require the special install are: CLC Journal since it has an outlook component and sets up a sync for the Outlook Journal. The Stowaway Keyboard driver since it had to ask me what language (the new driver doesn't do this...) The other 30 odd programs I have install straight from active sync.
Sep 11, 2005 | HP iPAQ HX2110 Pocket PC
IPAQ rx3115 calendar synch 1 hour off
The pc clock needs to be set to daylight savings time. To do this right click on the time on you pc go to the time/clock settings and then click on the time zone tab and below the clock is the box that says automatically adjust for daylight savings time make sure that is checked and then re-sync the iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ H2210 Pocket PC Logo
164 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
