Question about Logitech Cordless Action (9633200403) Game Pad
Promblem My left and right analog sticks can only move right, not left. Nothing else is broken
  • 1 more comment
  • atoyac Nov 22, 2007
    when i start playing a game the controler moves the game by its selve
    the left anolog and right only move to the right
  • Herbert Kietzer Dec 17, 2007
    I just bought 2 of them, and got the same problem with one of them...
Normally there is no reason to re-calibrate the Logitech Cordless Action Controller for PlayStation2. In rare cases where the mini-joysticks may need to be re-calibrated, you can use the process below. Please note that this process only works for the Logitech Cordless Action Controller for PlayStation2.
  1. Remove one battery.
  2. Hold the L1 and L2 buttons while re-inserting the battery. (NOTE: Do not touch or move the mini-joysticks at all during this time. It is very important that the mini joysticks are allowed to center themselves during this step or the calibration procedure will not be successful.)
The mini-joysticks should now be re-calibrated. Please note that in some cases you may need to resynchronize the gamepad and receiver after this procedure.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=1414
Posted on Dec 17, 2007
When I start playing a game the controler controles the game with out me moving anything
Posted on Nov 22, 2007
Analog stick are doing the opposite of what they should
I had this problem also on my sons xbox.. You must go into profile and then edit the settings.. In the default game setting you select the actions tba and have movement set as the left thumb stick.. His was set to the right thumb stick.. All sorted now.
Jul 03, 2012 | Microsoft Xbox 360 Controller
Left analog stick drifting left
Hello Iwn666,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
Nov 12, 2011 | Microsoft Xbox 360 Controller
The left analogue stick keeps moving the character around even when im not doing anything
Hello alsupjonatha,
Aug 07, 2011 | Microsoft Xbox 360 Controller
On cod my logitech controller's control pad moves my player but i cant move with the left joystick (they have been switched somehow)
You have to go through the game settings and ensure that you have set the primary control to be done by the left analog stick. In other words, make sure that you have the left-analog stick as the tool to move your player around while playing the game.
Also, if that doesn't work, there is a possibility that your left-analog stick is somehow jammed and as a result doewsn't perform the right function.
This could be a factory fault or one that arose as a case of mis-management. Whatever your result is, kindly let me know.
Hope this solution was helpful? Please comment for more information and thank you for using www.fixya.com
Jan 02, 2011 | Logitech Cordless Precision Controller for...
My right analog stick is broken. It sticks in one
hey chochie :-)
quick simple ansa to this....YOU DONT :-(
srry...
i have boxes of controllers with one analog stick broke (left or right) & even i dont fix them & i deal in controllers (i mod them)
Its a real big job to replace a analog stick when its damaged !
lots of de-soldering (to remove) (solder ****** working overtime)
& lots of re-soldering fitting the new (or used) one !
Trust me....ive tried ! I can do it...but its not worth the time it takes to repair !
srry maybe not the news you wanted to hear...but honesty the best policy !
take care :-)
Feb 11, 2010 | Microsoft Xbox 360 Controller
Right analog on ps3 gets stuck on top left direction
the circular thing that lets it move freely probably cracked, making it harder to move. i had to buy a new controller because of this reason.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
Looking for a ubisoft game manual and not sure if this is a location that will help..not much of a gamer, but need manual for ps2 Heroes of the Pacific game. I looked on the "ubisoft" site but didn't see...
FLIGHT CONTROLS blacklinespacer.gif Steering or Roll: Left analog stick Left/Right Change Pitch of Plane: Left analog stick Up/Down Roll Left/Right/Move Vertical Rudder Left/Right: Right analog stick Left/Right Throttle: Right analog stick Up/Down Engage Warspeed: R3 (click right stick)
blacklinespacer.gif COMBAT CONTROLS blacklinespacer.gif Give Wingmen Order: Attack: Directional Up Give Wingmen Order: Defend: Directional Down Give Wingmen Order: Break: Directional Left Give Wingmen Order:Form Upk: Directional Right Next Target: x.gif Closest Air Target: Hold x.gif Rear View: triangle.gif Cycle Secondary Weapons: square_white.gif Next Objective: circle.gif Closest Objective: Hold circle.gif Target Camera: l2.gif Fire Secondary Weapon: l1.gif Zoom In Gunsights: r2.gif Pause Menu: Start Change View: Select
From http://www.gamesegment.com/PS2/instructions.cfm/id/6386730
Nov 17, 2009 | Video Game Consoles & Games
Xbox 360 controller left analog stick
If you bought it brand new, contact Microsoft ASAP.
Otherwise, no luck. Just an unfortunate side affect of playing a 360.
Apr 04, 2009 | Microsoft Xbox 360 Wireless Controller
My sony psp analog stick is broken
take it to a shop eg,dicksmith,harvey noman and shops like that then then send it to sony and they fix it in 4-6 week free of charge;)
Jul 08, 2008 | Sony PlayStation Portable (PSP) Console
Logitech Cordless Action (9633200403) Game Pad Logo
315 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
