Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi ws-55813 horizontal hold
Set will not hold horizontally. Can power off the set and and the condition clears but returns after a while. Is there a horizontal adjustment that can be made or is the a service call?
  • bsportn Aug 13, 2007
    You can see the picture but it is broken up. If it is the video circuit is it worth replacing or after 4 years?
  • Anonymous Sep 20, 2008
    I have the same issues where the picture doesnot hold. When I first turn on the tv, the picture is ok but after about a minute, the picture scrambles. (broken up) multiple images of the same. for a while i was able to turn off and back on several times and the images will hold. but it's happenning more frequent and finally last night, it image just would not hold, it scrambles. like the horizontal hold is not holding.
    Genius:
  • 1,153 Answers
When you say horizontally, do you mean it collapse or it scrambles. Because the 2 are different problems. If you pictures shrinks or collapse then it is in the vertical circuit. and if it scrambles itself almost like you can see the picture but it is broken up over and over again, then this is video problems in video circuit. Need more info
Posted on Aug 13, 2007
  • Lashawn Robinson Aug 13, 2007
    Yes I really think so, I can tell you a possible fix to your set, only if it comes and goes. If this is the problem. Then if you look on your signal board there should be what we call a crystal, this can look like a silver small can with 2 legs and it is usaually by a big Microprocessor chip. sometimes it's yellow in color, but any ways you can take regular hot glue and cover the crystal which may say on it 33.33Mhz or different. What is taken place is that the signal going out is too close to the processor and causing a scramble picture. If not your problem can't hurt your set.Just remember saftey first. Unplug set
SOURCE:
Power goes off when truned on
Hello
The power supply starts ON and suts down immedieatly, means there is some short circuit with its main board. In most cases Horizontal output section will have the shorted component/s. You must ahve knoledge in electronics, and experience in troubleshooting the horizontal output section of your set.
Feb 15, 2012 | Mitsubishi WS-55819 55" Rear Projection...
Distortion, blinking, dark screen - now nothing
at the horizontal deflection yoke! maybe you have defective flyback! or horizontal yoke!
Sep 20, 2007 | Mitsubishi WS-55807 TV
My mitsubishi projection tv, ws55813, was losing horizontal sync intermittently, turn off and back on, sync was ok. turned off and back on, once too oftern, to solve sync prob and now I have blue screen....
There is a hard reset you can try on this set--it is done with the Mitsubishi remote that came with the set.
Confirm actual model number and I will tell you how to try it. The set will shut off after the reset(not the reset button some of these sets have on the front) and come back on channel 3 in the air band--any labels for inputs will be replaced by original input numbers etc.
No guarantee this will fix your problem but it will return the set to the condition it was when new in the box.
Let me know if you want to try this.
SD TECH
Oct 24, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Trying to replace capacitors in dm module
it is tight, and some what glued in place just pull firmly and straight up. it will come out ok.
Apr 03, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Picture won't hold it keeps flipping over and over
look for dry-joints on the guns and convergence boards
Apr 01, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Horizontal won't stop fluttering
call tech and suggest to repair the horizontal drive ..
Nov 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Timer light
does the light blink for more than 70 secounds? if it does go off after 70 seounds the keyboard lockout feature may be engages to unlock press and hold menu on keyboard for 10 secounds. If the set contiunes to blink after 70 secound after plug in then you maye have power issues or a possible bad digital board
Nov 04, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
225 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
