Question about Nakamichi SoundSpace 8 CD Player
Soundspace 8 - Disc eject / play problem
Greetings; I have been a proud and satisfied owner of the Soundspace 8 for a long time now, but I have developed a problem with the CD mechanism. There is a disc in the player and I cannot eject it with the on-board button or the remote. The unit will not play any disc either. Radio works fine, as do other inputs (e.g. Aux), so it is not an audio problem - appears to be a electro/mechanical issue of some sort. I have tried a cold power restart (unplug unit from wall) to see if it would run through its POST routine, but that did not change the behavior. When I choose the disc buttons (1,2,3. etc.), the green light is on in the "one" position, but pressing 2, 3, etc. changes the "1" position's light to orange instead of changing discs to position 2, 3, etc. When I press play, the status display changes to a "play" arrow and when I press the stop/eject button, the play arrow disappears (which tells me the control panel buttons are at least mechanically functional. However, I hear no play or spin-up of the disc and when pressing eject the blue dust cover light does not illuminate and there is no sound from the mechanism (it doesn't even try to eject the disc, it is just unresponsive). The dust door does not respond to the eject command either. Any help or direction appreciated. Thanks and best regards; _____________________________________________________________ KevFrey . . . . . .. . . . . .
  • FreyGuy Aug 31, 2007
    Hiya - I don't think it is a mechanical problem (no sound or change happens when pressing eject).
    Thanks for your help;
  • dmcmillan45 Jul 03, 2008
    This player has just quit working. Fuse blows and we replace and it blows again. No power. Can we send back for repair?
Get a new CD unit fitted. My repairer in Australia could not sort out the problem. Only solution a new unit - only problem was the new unit developed the same problem in just over 3 months - outside the warranty period! I am looking for a new/replacement one now
Posted on Oct 04, 2007
Hi Kev Frey, Have you checked the mechanism for a broken or loose belting or possibly a broken gear teething. With Regards, Edmund
Posted on Aug 13, 2007
How do i get a owners manual for nakamichi soundspace 8
This should do it.
http://pdfshack.com/nakamichi-soundspace-8/
Best of luck.
Dec 07, 2014 | Nakamichi Audio Players & Recorders
CD rom not responding does not spin, play or eject
the cd player has gone bad. make sure you have it set to cd for sometime's things get alil stuck
Jan 12, 2010 | Nakamichi SoundSpace 5 Shelf System
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
Aiwa xd-dv370 doesn´t play lens cleaner disc
The lense of the player may have gone week, since you have been using it for a long time. Replacing lense will be a solution to this.
Jul 09, 2008 | Aiwa XD-DV370 DVD Player
Nakamichi SoundSpace 8 System
check your power cord, check your 9 prong relay cord from power amp to deck unit, check your fuse that is in a little slot in the plug itself, most importantly check the 9 prong plug to the control unit itself, if you are mounted on the wall it could easily come out enough to not make connection. these units will take alot of bad voltage errors, if the only thing not working is your cd player you should still be able to eject it, if not it is power related, if it will eject but not play then your drive band is broke and unless you are very very mech minded take it to a repair shop who is nach. refered just look online for service try my ideas 1st you might get lucky, I hope I am right!!
Dec 23, 2007 | Nakamichi SoundSpace 8 System
Ejects CD'd rather than playing them
You probably have problem with central sensor on CD mehanism,it may be dirty,its doesn't give information when changing discs and unit "things" that you press OPEN.It can be very tricky do fix because you have to dissembly whole CD mehanizam and if you are not good in it its better to find a good service
May 03, 2007 | Nakamichi SoundSpace 5 Shelf System
Nakamichi SoundSpace 8 CD Player Logo
261 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
