Hello, my name is Ervin Bartha i got a system with an Abit GD8 Pro MB the videoboard is(new) in PCI bus the memory is (new) Kingmax 1Gb on 800.
When i try to switch on the system nothing happens on the monitor, tryed with several videoboards also in PCI-E bus.
When i take out the memory module i receive the beep alerts that the memory is missing, The cooler on the CPU is ok(working) no HDD or CDrom is connected.
If someone got any help please post it.
Thank You
Comments:
Mar 17, 2009
- Ram is ok, i had tried also to reset the CMOS with jumper, but it doesn't helps, but i found somewhere a trick when reseting the CMOS remove the baterry and leave the CMOS reset jumper active for 1 min, and after keep pressed the insert button when switching on the system, i t worked and i had also entered in the BIOS but after saving the settings in the BIOS the next restart result was tha same, again i cant see anything on the monitor neither the monitor led is turning green.
Maybe the BIOS is damaged or it can be something else?
Mar 17, 2009
- I had tried with several memory modules and the same also tested with memtest86
Mar 17, 2009
- Yes i had tried also to load Fail-Safe option and saved the settings but after exiting the BIOS i had the same issue.
I had also upgrade the bios to the last rev. GD8p_14 but it is the same result.
Mar 18, 2009
- This is an ABIT MB and not new, it was working before, but 1 year was not powered on and stayed in a warehouse
Mar 18, 2009
- Nah i think not i am ESD equipped with special ESD shoe i am working in a Electronic board manufacturing factory all the persons are equipped with protections. It is strange because i can use the PC every time i reset the bios without battery but after a new restart or a shut down all is gone.Nov 10, 2009
- the memory it is ok, i had tested it with memtest86 on other sysytem
