Question about Toshiba Satellite A105-S4004 Notebook
Screen has cracked
Hi! We've had our laptop for less than a year and I'm not sure if it is defective or not but I came home after work to use it and opened it and the screen had a small crack in the uppper corner. Recently this crack has grown and taken over the whole screen and we can no longer use the laptop. We are not sure if this is covered by warranty or not since we just bought the laptop this year brand new, or what we can do. We've looked around at new screens but cannot find one less than $291.00. We don't really want to have to spend anymore money on this laptop and hope that this would be covered under the warranty. Please let us know! Thank you!
    Problem Solver:
  • 16 Answers
The only way to see if the laptop is still under warranty is to contact Toshiba directly. They have a warranty information site online at: http://www.csd.toshiba.com/cgi-bin/tais/su/su_navShell.jsp?cf=su_wa_cent.html
Posted on Aug 13, 2007
White turned pink
Hi Elizabeth
it sounds to me as though the cable which connects the screen to the mainboard has become damaged or worked loose. You will need to take the laptop to bits to check that the connection is secure, or to replace the cable. Hope this helps.
Feb 18, 2013 | Dell Inspiron 1525 Laptop
I banged on the keyboard of my laptop now the screen has all these colors going across but you can not see anything. What happened and can it be fixed?
You screen is cracked. It will require replacement.
If it's not the screen, then it's the LCD lamp, which is generally just inside/beside the joint of the screen (where it meets the laptop body). You can try tapping the area gently, to see whether it falls back into place, but if you've got permanent colour defects, it's probably a broken LCD.
May 06, 2011 | Gateway M-7315U Notebook
My Asus laptop higes were so stiff that now the have broken off the main laptop base (screen moves aroutionund) Please advise on best sol
The BEST solution is to buy a new set of plastics for the laptop.
I have techniques for repairing such an issue, but it's complicated and requires a lot of skill and practice.
If you can find an identical unit on ebay or something that has a cracked screen or is otherwise defective, these defective units make great homes for working laptops!
Feb 25, 2011 | ASUS A8HE-X1 Notebook
I have a acer 4740g laptop.I ve got display problem.It shows several lines and i cnt work on it.Recently it got little pressed on its display.Can any1 help me?
Hello shreejan_man
First thing to do is to test the screen. Also you have not mentioned if there is any cracks or damages.
Plug the laptop to an external monitor (any type will do). If the display on the external monitor is OK then it means the laptop screen is damaged.
If the display on the external screen is the same as the laptop then the problem is internal with the graphic chip or the video contacts.
this laptop is not that old since acer released this model last year. Check you warranty status on it. Some acer laptops come with two year warranty. Check the laptop carefully, if there is no sign of physical damage, (cracks, chips ...) then take it back as a warranty issue.
Good luck
please leave comment, vote if this helped.
Feb 24, 2011 | Acer Computers & Internet
My screen has horizontal lines across half of the screen. I hooked up to a external monitor and it worked fine. What is the problem?
It would physically be in the LCD screen of your computer. If the monitor is working fine therefore there is nothing wrong with the video processing output or the drivers in the operating system. It would be in internal crack on the LCD or a loose connection with the LCD screen and the motherboard.
Its best to have your laptop checked by a service technician and dont just disassemble it by yourself to prevent accidents. Worst case is that the LCD needs to be replaced if really found cracked/defective.
Hope this helps.
Jul 08, 2010 | Toshiba Satellite A105-S4004 Notebook
Can i adjust size of display as a cracked screen has blocked some
Hi. The best thing to do is to get an external monitor and connect it to your laptop. Press Fn+F8 to show the display on your ext monitor.
^_^
Jun 07, 2010 | Dell Latitude D600 Notebook
Gouge in laptop screen. Less than half inch long
Hi:
is the display distorted under the scratch?
If it is, the problem could get worse. If your scratch is just on the plastic surface, the problem shouldn't get worse.
Oct 29, 2009 | HP Pavilion dv6000z Notebook
LCD screen
Probably not as a cracked display usually results from dropping or sitting something heavy on the unit.
If it just cracked under normal use, then this would be a defect and it should be covered under your warranty. The only sure way to know is to take it in and try your best to convince them that this is covered under your warranty.
FYI, the warranty is probably from the manufacturer, unless you got some extended warranty through Best Buy? Otherwise the stores responsibility varies from state to state.
May 07, 2008 | Computers & Internet
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
