Question about IOGear (GBU211) Bluetooth Wireless Adapter
Can't install my program/drivers
A message pops up saying that my laptop can't install the driver because it can't verify the publisher.
    President:
  • 1,114 Answers
This is just Microsoft standard message to say they have not tested the driver themselves. Providing the file comes from a good source i.e. install CD then it is probably fine. Just go ahead and install it. If you feel concerned then set a windows restore point before you run it then you can back the change out easily. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2007
Why
is the laptop have a Bluetooth driver installed? If none, go to acer website to download and install the driver: Here is the link for acer driver support. http://us.acer.com/ac/en/US/content/drivers
If you are not sure what driver to download, you must verify it first by downloading the vendor detection at
http://global-download.acer.com/SupportFiles/Files/HWID/APP/HWVendorDetection.exe
Then run the program to verify your driver vendor.
Please note that in order to verify your drivers, it must be turned on. (Specially or laptops having a side switch for wireless connections)
May 04, 2014 | Acer Extensa 5210 5220 5620G 5620Z...
Ebookman EBM-901 not being recognized as connected on Windows 7 x64. Windows troubleshooting says USB Virtualization stub has a problem, suggests reinstalling, attempts that, then says it failed to fix...
Welcome to FixYa!
Install the drivers supplied by the manufacturer in Windows XP SP2 compatibility mode.
First, restart the computer is clean mode. The Clean Mode temporarily disables all the programs that are being loaded during the startup of your computer.
  • Click start.
  • Type msconfig in the search box.
  • Click on msconfig from the results.
  • System Configuration Window will open.
  • Click the Service tab.
  • Check the box that says Hide all Microsoft services on the lower left corner of the window.
  • Uncheck all the boxes in the list.
  • Click the Startup tab.
  • Click on the Apply button.
  • Click the OK button.
  • You will be prompted to Restart.
  • Click Restart.
Install the driver in compatibility mode.
  • Locate the driver installer file (Application file with .EXE extension)
  • Right click on it. Click Properties.
  1. Click the Compatibility tab.
  2. Tick the check box that says Run in compatibility mode for.
  3. Choose Windows XP SP2 (Service Pack 2). Do not choose Windows Vista.
  4. Tic the check box that says Run this program as administrator.
  5. Click Apply.
  6. Click OK.
  • Connect the EBM-901 to the computer.
  • Double click the driver installer file to start the installation.
  • You may be required to restart after the installation.
Thank you for using Fixya. Have a great day.
Jas247
Jul 21, 2011 | Franklin Electronic Publishers, Inc....
It cant run the driver you gave.. the publisher could not verify..
That's an unsigned driver, which will not install in Windows 7. In Vista and Windows XP it will work, but since you did not list the OS...?
If you cannot find the right driver, try a driver finder program to locate it.
Jun 04, 2010 | Logitech Webcam
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
My Printshop 15 does not operate properly, and i am
Not sure what your exact message is but on their support site it listed this:
Invalid Page Fault in Module ADBOOK.EXE Description Solution While trying to print or preview in the Ultimate Mail Manager Address Book (included with The Print Shop® 15), the message "ADBOOK caused an invalid page fault in module ADBOOK.EXE" appears. This error is usually the result of an outdated or incompatible printer driver. Checking for proper settings or updating the printer driver or both can help to resolve the issue. The remainder of this technical note describes how to proceed. Follow the procedure below to help resolve the issue.
  1. Close all programs and return to the desktop.
  2. Click Start, choose Settings and select Printers.
  3. Right-click the icon that represents the printer being used and verify that Set as Default is checked.
  4. Choose Properties from the menu that appears. The printer Properties window will open.
  5. Click the Details tab.
  6. Click the Spool Settings button.
  7. Change the Spool Data Format to RAW.
  8. Click Apply and click OK.
  9. Close the Printers window.
  10. Open The Print Shop® 15 and Ultimate Mail Manager and try to print again.
NOTE: If the issue continues, contact the printer manufacturer and request an updated printer driver and directions regarding the installation of the updated printer driver. Typically, an updated driver can be obtained from the manufacturer's Web site.
If the error reappears after downloading and installing the new printer driver, continue with the following procedure.
Install an Emulation Driver
  1. Install a suitable emulation driver. For help identifying and installing a suitable emulation, contact the printer manufacturer.
  2. After the emulation driver has been installed, launch and use the program. The issue should be resolved.
NOTE: For some printer models, it may be necessary to switch back to the original printer driver when using a desired application in order to gain full functionality of the printer.
Dec 06, 2009 | Broderbund The Print Shop Pro Publisher 15...
While installing logitech wingman 3.0 to vista.A message popped up saying incompatable drivers.How and where can I get a driver for this game to use with vista.I tried looking but am unable to figure out...
What is the exact message you recieved? Was Windows complaining about a driver that wasn't verified, was it saying it was out of date?
For the latest drivers straight from Logitech go to:
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Then select the correct device, operating system, etc, and you should be able to download the most current driver.
Jun 23, 2009 | Video Game Consoles & Games
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Kodak Easy Share 5300
You need to update your Kodak Easy Share and your printer drivers or try uninstalling and reinstalling the drivers .
The reason you are facing the problem is because the present drivers are not compatible with Publisher
Jan 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Problem installing the driver
Mine did the same thing - just ignore it and click ok - it will work believe me - just do it and it'll work.
Sep 12, 2005 | Creative Labs PC-Cam 550 Digital Camera
IOGear (GBU211) Bluetooth Wireless Adapter Logo
44 people viewed this question
Top IOGear Computers & Internet Experts
Damen Wong
Damen Wong
Jose Velazquez
Jose Velazquez
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
