Question about Motorola Mobility V3 Handsfree Headset with Connector fits MOTO Razr V3 Headset
Help yday i i called optus up to get my mms to work an it still came back unable to send then after that it had came up wif setup inbox i fixed that this morning but then it came up unable to send messages i dunno wah the problem is i need help the phone was given to a friend an then given to me or is there a password that i can reset master clear if so help plz cos its stressing me out really badly
    Genius:
  • 1,153 Answers
Do not provide the user manual, however, function of the H350 is very similar to the H500 and we are providing a link to the H500 user guide. Just copy and paste this link into your browser and Motorola will explain how to connect your Bluetooth Headset. http://telecom.hellodirect.com/eBiz/pdf/cellphoneheadsets/Motorola_H500_Manual.pdf
Posted on Aug 23, 2007
6ya staff
SOURCE:
Unable to configure my mms with optus prepaid. How do I do this?
call your service provider and ask them to send the mms settings to your phone
Sep 14, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
Need wap/mms settings for optus (aus) for cect i9 phone
If you have a I9 you must go to this site. very helpful every question you have has been asked at this site. Regestration is free.
http://www.i9forum.co.uk/
Most setups are listed directly on this site. I took this qute from someone asking the same question.
I didnt see the thread they were ytalking bout, but they are suggesting stting it up like the Nokia 2610. I would recommend posting this question again on the above site. Below is what I copied from there.
Hi I'm in Sydney and use Optus mms and wap with no problems. If you look in this thread under the topic Easy configure MMS. Follow the instructions to the Nokia site for the 2610 and you should get a text back to set up MMS and the internet. Good luck It worked fine for me.
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
Unable to download or send MMS on Tmobile Dash
You need to set up your phone's data connectivity: From your phone, run "Connection Setup"(go to Start >> All Programs >> Accessories; select your country and operator) Hope this helps
Mar 29, 2009 | T-Mobile Dash Smartphone
Problems sending mms
It could be based on your location and the amount of service towers that are in your area. To send an MMS you need a good, strong connection. Try these first.
You need to set it to Vodafone in two places - first of all you need to go into messages, then press your menu (top center) key, then go into "inbox setup" or "message setup" (can't remember what it's called). Then select MMS message setup, scroll down to the last option (which I think from memory is called "server info") and make sure it's set to use the Vodafone option.
This is in addition to making sure that "web sessions" is defaulted too.
Okay, now both those options are set, give it another go. If it still doesn't work, give the manufacturer a call - they'll also walk you through the settings and make sure they're correct. There may be something at their end (on your service) which they need to change to make it work.
Please rate FixYa!
Jan 12, 2009 | Motorola Mobility V360 Cellular Phone
Text messaging
am unable to send SMS messages? space.gif space.gif answer.gif As a set limitation to the phone's design, if the SMS Inbox is consumed, the phone's alternative is to send as an MMS.
If a customer is calling and their phone is sending SMS messages as MMS messages, please advise them that they may have an excessive amount of SMS messages in their inbox. Advise them that deleting some or all of these messages should correct the problem.
To delete messages:
  1. Press Menu
  2. Scroll to and Select Messaging
  3. Press Options
  4. Scroll to and Select Cleanup Messages
  5. Scroll to and Select All, or Inbox
  6. Press Yes, to Delete Messages
Oct 18, 2008 | Motorola Mobility RAZR V3
I bought an lg tu 550 unlocked and have converted to optus,i would like the settings and procedure for mms to setup and work please
HI there bushyblanch, I will assist you!
To setup MMS on your new handset is a simple process, all you need to do is follow the following link to the operators MMS setup page, you will be sending MMS in no time.
Link - Click Here
Hope this helped you
Thank you for your question
CrashMech
Sep 14, 2008 | LG Cell Phones
MMS setup
You will need to take the phone and have them setup you MMS manually...or you can contact OPTUS Customer service line and have them assist you.
Sep 06, 2008 | Motorola Mobility RAZR V3
RAZR V3XX - sends my texts as MMS, rather than SMS...
I had this same problem and called Motorola for support. The solution is to clear text/mms message inbox and outbox. The default setting on my phone was to never clear the inbox but I changed that to remove messages when they are 10 days old, I have not experienced the problem since.
Nov 07, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Mms setup
my phone has no mms service record
Sep 13, 2007 | HP iPAQ hw6915 Smartphone
Radio Communications Logo
107 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
