Question about Technics SC-DV290 System
'stereo' speaker problems
The satelite speakers work fine, but the 2 main stereo speakers sound garbage ! there's high and low frequency wiring options and neither of them produce good quality sound. the low frequency (european) setting is so muffled its impossible to make out anything, and the high frequency (for australia) setting has no bass behind it at-all. a signal test can only be heard using the australian set-up. oddly enough, when i use a set of old aiwa speakers in their place, the system as a whole is amazing ! can anyone suggest whats going on, and a possible solution please :-) p.s. as i continue to use the aiwa speakers, am i doing any damage ? i would prefer to use the technics speakers provided. thanks in advance, Fil.
    Guru:
  • 417 Answers
Yer man there a load of **** i've got 2 x DV290's one for the back of my studio & one powering the front,your lucky you only had 2 **** speakers i had 4 lol.
but there is light at the end of the woofer,they have to be wired together its as if one makes the other one work,so you put GRAY & BLUE in you get BASS or hum ,you put BLACK & RED in you get HIGH or top end you put all four in you get nice mixture.
I've also had it another by mistake & it worked, i put the + & - side by side instead of top & bottom so it was RED / GRAY & BLACK / BLUE if you know what i mean.then cut the plugs off the surrounds & wired them in aswell & it's all good in de hood.
oh a tip before i go,get some rubber legs off the bottom of something or the casters off an old chair or stool & GET THEM SLAPPED BETWEEN THE AMP & THE SOUND PROCESSOR for ventilation coz Fu*"*k me they don't half get hot man!
good luck pal....later
Posted on Aug 04, 2010
Infinity tweeter
okay ill answer this as best to my knowledge.There inside is a wire going to the woofer or the low frequency speaker.then you have the tweeter which is for the really high frequency.Inside there is either a capacitor or a crossover a capacitor is a small can looking piece and the croossover is a coil or wires.But what this does is stops the tweeter from receiving the low frequenies that should be directed to the woofer as it also stops the woofer from getting the high frequencies.You need to open it up and see if any wires are loose or disconnected or if anything dont look right if there is a capacitor look on the top and see if its buldging if it is it is about to pop which that could be your problem or it may have already.Do this when you open it up will you tke a video and show me the inside of your speaker.
Mar 17, 2013 | Samson Resolv 65a Main / Stereo Speaker
Do i hook the speaker wire in to the top or bottom wire recepticles of the speaker
These are bi amp capable speakers...if you have the jumper in place (connects top and bottom terminals together) it's set up for standard full range connection - you can use either set. If the jumper is not in place, it's set up for bi amp which means you would connect your low frequency wire to the bottom terminals, and the high frequency wire to the upper terminals.
Aug 20, 2012 | Sony SS-X70ED Main / Stereo Speaker
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
Do i have to remove the pin between the two speaker treminals on my old mission 780 speakers before i bi wire them
Yes, the two sets of terminals are for the tweeter and bass driver.
When you bi-wire you want the low frequencies to go only to the bass driver and the high frequencies to go to the tweeter..
Please see this link for more information:
http://www.brilliancehifi.co.uk/how-to-bi-wire-speakers.htm
Please rate my answer if you find this useful.
Thanks,
Chris
Mar 02, 2011 | Mission 780 Main / Stereo Speaker
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
Aiwa cx na555u
Dear shelnaaqua,
Please connect the headphone to your system and check the sound quality,If it sound good then the connection of the speakers are not ok. This system has HI & low frequency output. Connect woofer to LOW frequency output and tweaters to HI frequency.
please take trouble to vote for me if this solve your problems
ramesh22
Jun 07, 2008 | Aiwa NSX-A505 CD Shelf System
HOME THEATRE SYSTEM
I think you must change the settings and try it out! it will make a great change.
Dec 07, 2007 | Audio Players & Recorders
Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Sep 07, 2007 | Audio Players & Recorders
Technics SC-DV290 System Logo
218 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
