Question about Kensington StudioMouse Wireless
Flashing red light on the Kensington wireless mouse base
What does it mean when the red light is flashing on the charger/base of my Kensigton wireless mouse?
    Problem Solver:
  • 12 Answers
My adapter says 5.6V DC 600mA tip is positive
Posted on Jan 26, 2010
I still have the manual for my mouse.  Model number 64321.
When this mouse was manufactured it used NiCad batteries which developed a memory much more than the newer batteries.  The older NiCad batteries needed to be conditioned occasionally so Kensington provided a way to do that with the charging base.
The red light is for indicating discharge status of NiCad batteries.
The red light will flash quickly when you press the battery discharge button on the bottom of the base.  This indicates that you now have 5 seconds to place the mouse in the charging base for battery discharge.
The red light will flash flash more slowly when the battery is being discharged.
After the battery is fully discharged, the base will then charge the batteries.
It should be noted that very few manufacturers of products that utilized NiCad batteries provided a "battery conditioning" feature.  Kensington was unique in this regard.  Battery conditioning allowed NiCad batteries to have a longer useful life.
Now maybe you can help me....  I lost my power supply that plugs into the USB connector.  If you have yours, can you tell me what the output voltage is and what the polarity is of the inner pin.  This will be marked right on the power supply base.
I plan to just get a generic power supply from Radio Shack, but I need the voltage value and polarity.  Until then, I can still use the mouse, but it won't charge.  FOr now, I'm just using standard AAA batteries.
Thanks.
[email protected]
Posted on Mar 26, 2009
SOURCE:
Unable to use keyboard, it's charged don't know what's wrong
If the charge button is red, it means it is not connected via bluethooth
Oct 04, 2012 | ACCO Brands Kensington PilotBoard Wireless...
Kensigton assistone bluetooth problem
It will not pair with another mobile phone, if that's what you were trying to do.
Jul 24, 2012 | Kensington K39200 AssistOne Handsfree Car...
I successfully installed the driver for the Kensington pocket mouse on my S7 notebook, but I cannot activate it to take over the job of the touch pad.
Wireless Installation
Plug in the receiver to your usb port. Install batteries to mouse.
To establish a wireless connection, press the connect
button on the end of the receiver. Then, press the
connect button on the bottom of the mouse.
Click a button on the mouse to go..
Repeat this procedure when replacing the batteries.
IMPORTANT: This wireless device is similar to an FM radio, by
adjusting the antenna you can get better reception. You may
also want to experiment with different locations and positions
of the receiver.
The little light on the receiver should light up and flash fast untill it sees the mouse signal.
Nov 18, 2010 | Kensington PocketMouse 72214
Kensington Wireless Mouse: 72314 Constantly fla...
White is not good for an optical mouse. You need a dark, solid color. When I find myself without a mousepad, a piece of black construction paper seems to work well. Good luck.
Jan 19, 2018 | Computers & Internet
Kensigton adapter beeps power of
dear sir good day try to test the adapter with a other pc and then if it go wrong agin so you must call the dist. for replacing it thank you
Dec 27, 2009 | Kensington (K33348) Bluetooth Wireless...
I have a kensington wireless mouse. the wireless keyboard works, but the mouse does not. The red laser light is on, but it won't move
Have you tried to resync the mouse with the receiver. Usually,you need to press the button on the reciever first, then quickly hit the button on bottom of the mouse.
Oct 05, 2009 | Kensington Computers & Internet
Kensington wireless mouse doesn't work on Mac laptop.
Kensington wireless mouse is compatible with this system:
PC-Windows® 98, Me, 2000, or XP with USB port
USB Macintosh® with OS 10.1.5 or later
USB Macintosh® with OS 8 and 9 device will only function as a 1-button mouse
If you buy this item you have a disk utility on it and provide the software to run on the system. If not you can download it at this site: http://us.kensington.com/html/4398.html
Jul 08, 2009 | Kensington PocketMouse 72214
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Kensington StudioMouse Wireless Logo
2,359 people viewed this question
Top Kensington Computers & Internet Experts
Alun Cox
robert roberts
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
