Question about Vizio GV42L 42 in. LCD Television
Sputtering,muted,crackly audio so i just bought a GV42L Vizio, every 20-30 min on SDTV the audio will either mute out, crackle, break out in a jumble of pitches for 3-5 seconds then return to normal for another 20-30 min when i play a dvd thru my upconvertering player and hdmi cable, not a single problem for the entire duration of the movie. whats the deal?
  • 1 more comment
  • mangelico Dec 14, 2007
    The Speaker at the base of my Vizio 47 in. HDMI LCD TV makes a sputtering sound. Does this in short bursts and long bursts. And occurs on all modalities...Cable TV thru HDMI cable or coax cable and on DVD.
    Not sure this issue is related to the speaker or the signal received from the cable box and DVD player.
    I appreciate any suggested solutions. Thanks.
  • Anonymous Sep 18, 2008
    I have cable and my vizio 42 flat screen tv has made crackly sounds. Today there is no sound at all. We just added a HD cable box but there was sound for a few days.
  • plbonnin Nov 14, 2008
    We have the same TV and the sound won't play on some channels on and off. Then sometimes sound from one channel will play on another channel. It will make a loud crackle sound and then no sound at all will play.
    Problem Solver:
  • 4 Answers
I have a GV42L 42" manufactured in march 2007. It works perfect except the screen has a fracture on it. The warrabty is voided because we damaged the screen. I can sell this to somone who has a good screen but needs boards or speakers, etc. Or I will buy your tv that has a good screen but damaged boards in it.
[email protected]
Posted on Sep 06, 2008
Do you have direct TV....... Direct Tv does that!!!! not the TV
Posted on Oct 31, 2007
SOURCE:
GV42L HDTV picture ok but no sound.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Feb 25, 2016 | Vizio GV42L 42 in. LCD Television
The sound has become very low and crackly, and when I add external speakers, I get crackling and/or a big squealing. It worked fine until 3 days ago model T61 7662 CTO
My first impression is that the reason for the crackling and the squealing on external spreakers is probably from the onboard mic. My first suggestion would be to go into the sound settings and mute the microphone and see if the problem still exists. If it has gone then I would clean the area where the mic is of just keep it muted and use an external one.
Jul 21, 2010 | IBM ThinkPad Soundcard
I cant unmute my 42 vizio plasma , i dont have
hi ! i have here one code for your TV, you could try it 0081 hope it helps. goodluck!!!
Oct 12, 2009 | Vizio GV42L 42 in. LCD Television
Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Sep 12, 2009 | Vizio GV42L 42 in. LCD Television
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
Vizio GV42L
Call vizio asap they will have a tech come and fix it free.. after the manufacture warrenty runs out they want to charge you 6--$ to fix it here is the number! 877 698 4946
May 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
GV42L
I had this same problem. Vizio sent someone out to replace the motherboard. It didn't fix the problem. Since it was under warranty, they replaced it with a newer model VU42L. Doesn't have this problem, but it has others.
May 02, 2008 | Vizio GV42L 42 in. LCD Television
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
Vizio GV42L 42 in. LCD Television Logo
385 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
