Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Not cooling my refrigerator is not cooling, the freezer is not freezing and I don't hear any noise from the back of the refrigerator I really can't tell that it is on, what do you suggest that i do?
  • 63 Answers
TRY TURNING THE DEFROST TIMER SEE IF IT IS STUCK INTO DEFROST IF IT STARTS THEN BUY A NEW DEFROST TIMER
Posted on Aug 30, 2007
SOURCE:
Not cooling or freezing
Hi Mick, this is AP.
I understand you are experiencing a no cool situation in your Frigidaire refrigerator. On your model, FRS26R4A, specifically the first thing to check it to make sure the refrigerator and freezer controls are not set to "0", turning the Freezer and Fresh Food Controls to "0" turns off the compressor and prevents your refrigerator from cooling, but does not disconnect the power to the light bulb and other electrical components. If you hear the noise coming from the freezer compartment it could be something blocking the evaporator fan which would cause warm temps in the fresh food and freezer section. If the noise is coming from behind the appliance it could be something in the condenser fan or the compressor may be locked up. I would definitely recommend contacting an authorized technician to repair your appliance if you find the temperature controls are not the cause of your high temperatures in the refrigerator. I hope this information helps.
Thanks,
Apr 01, 2014 | Frigidaire FRS26R4A Side by Side...
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
Freeze doesn't freeze and fan in fridge is now making noise
Usually when the fan in the freezer is making noise it is because there is ice built up and it is hitting the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung RB1955VQ Bottom Freezer...
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Not cooling/freezing
Can you tell me more about your model GTS22IBMBRCC Are the lights on inside, are and fans running, do you hear any noise like clicking or the compressor trying to start. Is there a layer of Ice in the rear of the freezer? I can help just please respond with an answer, Thanks, Sea Breeze
Aug 08, 2009 | GE Refrigerators
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
Freezer won't freeze
Sounds like you might have a bad relay on the compressor or the compresor is stuck and cycling on the overload... if you listen closly you should hear a low hum or buzz then a click... repeated ever 5-10 minutes tell overload cools and trys to restart again
Sep 02, 2007 | Frigidaire FRS23KF7AB Side by Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
93 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Ekse
jasbo
jasbo
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
