FixYa.com
Tags:
Lexmark P4350 All-In-One InkJet Printer
Piece has fallen out of printer
posted by schmoopee98 on Aug 12, 2007
Help! I long, thin piece of plastic has fallen out of my printer. It has a hole on each end, and I can see hooks on both sides of the printer that it might hook too. However, when I try to run this thing piece behind the ink cartridges, it appears to be too long. Does anyone know what this piece is? I know that when I try to print now the cartridges slam up against the left side of the printer and then refuse to move again. Does anyone know how to put this piece back in my printer? Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 25, 2008
FixYa! (100)
SmarT-Arse
Rank:Wiz Wiz
Rating: 93%, 39 votes
Yea I had the exact same problem with my Lexmark X1185
Was very lucky I didnt throw out the clear strip thingie before learning what it was :)
Anyways the strip itself passes through a shader sensor located on the rear or the cartridge carrier.( see pic 1 ) .
The second picture shows everything else in close detail Including which side of strip goes where.
Pay attention to the spring (circled in yellow) because i believe it is the cause of the whole problem...The spring end was pulled straight or has too little tension .
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 16, 2007
FixYa! (100)
Garfunkel01
Rank:Wiz Wiz
Rating: 85%, 100 votes
it actually is a sensor so that the printer knows where the print head physically is. it actually goes "Through" the carriage that holds the ink cartridge and links over both extreme sides of the printer. it's usually got a spring on one side or the other, so you may have to pull carefully on the one tab to make it fit properly.
take a peek and see if you can find where it should go ..
i can get you some pix if you require...
Comment by Garfunkel01, posted on Aug 16, 2007
goes through the carrier
Solution #3
posted on May 22, 2008
Not Rated (0)
Tim12198
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This same piece gets dirty and needs to be cleaned every once and a while. If you get misaligned test prints or jagged text, clean this strip & print will be crisp and sharp again.
This Problem Also Relates To: HP PSC 2110 All-In-One InkJet Printer HP Photosmart D7160 InkJet Printer HP DeskJet 3325 InkJet Printer HP DeskJet 5150 InkJet Printer HP DeskJet 6122 InkJet Printer HP Photosmart D5160 InkJet Printer HP DeskJet 1220c InkJet Printer
Can you Help with these Printers problems?
deleted software by...
can this be fixed Answer This...
it didn't work
its still reading "Install... Answer This...
Carrier Jam
I have a lexmark 6200 series.... Answer This...
lexmark p4350
i have installed from disc but... Answer This...
my all in one wont scan
when i try to scan from my... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
