Question about NAD T531
"check disc" Hello - 95% of discs will now not play in this DVD player. It looks as though it's going to load them up but instead just comes up with a black box saying "Check Disc". Any ideas of what I can do? Many thanks for any help...
I had a problem with my T531 similar to this and found that the area around the lens focus area was totally covered in dust/fluff as though it we acting as a "dirt magnet" every where else inside was clean (could this be a unforseen problem in the design?) once carefully cleaned the unit worked well finding discs and playing like when it was new.
Hope this helps
Posted on Jan 12, 2008
My nx501 says invalid disc when I put a cd in I
Clarion NX501 Owner Manual Installation Manualit looks like this is mainly a dvd player,it does play disks with mp3's and wma files but,not compact disc files,read the manual,try a recorded cd with mp3s,
DVD Player System
Digital Versatile Disc System with CDDA capable
Usable discs:
DVD video disc, Compact disc
Frequency Response: 20 Hz to 20 kHz
Sound/Noise Ratio: 95 dbA (1W Ref)
Dynamic Range: 95 dB (1 kHz)
Distortion: 0.05%
Video system: NTSC/PAL
May 22, 2015 | Televison & Video
Coby LCD tv with side loading DVD player, my daughter apparently played with it while I was asleep- I turn it on to watch a dvd now, the dvd is inside (I don't think it's stuck) but won't come out by the...
Mechanical fault. Contact any service technician. The disc loading mechanism should be taken out from the TV for repair.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 26, 2014 | Televison & Video
Dvd wont play disc root comes up?
When you load the DVD, instead of the content loading, the word "Root" comes up? This means the content is either corrupted, the disc is dirty, or damaged. In other words, the laser is not able to reach and pick up the magnetic information on the disc. Does this happen with another DVD player? Try doing that first. In the meantime, clean the disc. If the disc can't be read by another DVD player, then the disc is at fault. If another DVD player can load the disc with no problem, the original DVD player you used, may have a dirty lens (what the laser shoots out of), or the laser is not moving at all. If this is the case, the DVD player is broken.
Nov 25, 2014 | Office Equipment & Supplies
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
Why does my player display
Sorry, the player is dieing. i had this player with the same problem.
Jul 05, 2010 | Cyberhome CH-DVD 300 DVD Player
Discs will not play. After loading for about 1 minute no disc note comes up. Discs have been cleaned and neither dvds or neo discs play.
The reason the player wont play the disc is either because the lens is weak or dirty.
Try to clean the lens with a lens cleaner and test with a DVD disc.
If it does not work, then it means the lens is weak and needs replacement.
To replace the lens, open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
Take care.
Jun 15, 2010 | Televison & Video
Cant get pre-recorded disc's to play in my recorder it comes up with the message "this disc will neither play or record" any ideas?
hello,
the reason the recorder comes up with the message "this disc wont play or record" simply is that the format of the disc is not compatible with the player.
1. check the format of the recorded disc,
2. and check the formats the recorder can play to confirm this.
take care
Jun 03, 2010 | Sony RDR-VX420 DVD Recorder/VCR
DVD player repairing
Double-check your DVD player's user manual/spec sheet to see if it plays Mp3 format files at all. Find out, specifically what kind it can read.
If your Mp3 disc is a DATA CD instead of an AUDIO CD, then nothing besides a computer is going to play it.
Sep 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Can't play dvd
Maybe your dvd got some capacitors dried on the power supply.
But you can also clean the laser lens maybe is dirty.
Jun 21, 2008 | Cyberhome CH-DVD 300 DVD Player
Intermitten problem
How's your situation going?
Worldvet
Jun 09, 2008 | LG RC185 DVD Recorder/VCR
NAD T531 Logo
178 people viewed this question
Top NAD Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Joaquim Martins
Raj Patel
Are you a NAD Televison and Video Expert? Answer questions, earn points and help others
