Question about Magellan RoadMate 700 GPS Receiver
I have the magellan 760, not have sound
I run the diagnostic test for sound, and not work, not have sound I clean with contac cleaner but is not work. Could you indicate what is the next step I need to do?? Thanks
    Scholar:
  • 76 Answers
Seriously, I believe your next step is to have the device inspected/repaired. At least you could call the manufacturer for FREE advice and FREE pricing. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
My magellan 760 doesn't acquire the satellites anymore. I already pressed reset gps through diagnostics but still doesn't work.
Hey lluny,
Good to hear you've already tried doing that.
There's a silver/black (diff. models = diff. color) cable inside your unit that sometimes comes unplugged. You'll see it as soon as you start opening your unit. So soon that you'll want to be careful when you are first opening. Make sure it's plugged in securely, I'd even unplug it and plug it back in.. but that may be risky & put too much pressure on the base solder. The last thing you'd want to do is permanently damage your main board.
Let me know how this works out and if you have any questions. If you do attempt to pull the cable to unplug/replug try to squeeze gently
-Daniel
Jan 05, 2011 | Magellan Roadmate 760 GPS Receiver
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
I'm trying to update a Magellan map update on my 760
plke1691
I think your problem is that you are using XP with SP 3, you cannot use anything more than XP SP2, so find yourself a friend that have an older operating system and update it. I bet you will not have any problem
Auto Nav 2000 aka GPS4ME
Apr 30, 2009 | Magellan GPS
I need an upgrade for my magellan Roadmate 760
You can download an upgrade for this unit from the Magellan website for free. Maps can be upgraded but they cost about $80, and that doesn't seem worth it to me. See if that works for you.
Dec 13, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 does not find satellites
I recently i had the same issue. Open the four screws from back. remove the back cover carefully (tahe care of the attached cables).
check the atena wire connection (gray thin wire). both the ends should be seated firmly.
in my case, soldering at one end was broken. had to resolder. its working now.
Nov 04, 2008 | Magellan Roadmate 760 GPS Receiver
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Roadmate 760 is stuck in current location
enter diagnostic mode. initialize gps. stay in place for 1 half hour. if the location still does not change find a highway -- the signal sometimes only kicks in on the highway
May 21, 2008 | Magellan Roadmate 760 GPS Receiver
MAgellan Rodmate 760
You should return it and get another one.
Jun 15, 2007 | Magellan Roadmate 760 GPS Receiver
Voice instruction problem
I'm guessing the touch screen is working fine regardless of the sound? What you'll need is contact cleaner and a thin cleaning rag. Disassemble the unit, being very careful when you first open it up to UNPLUG the RF cable that could break off if pulled too hard. So, once you get the 4 screws off, open the unit just a little bit.. reach in and unplug the RF cable. It will help your percentages of success if you were grounded somehow in this process. Take the HDD off the back of the mainboard (big board). Isolated from the rest of the unit, spray the contact cleaner directly into the volume knob.. then while still wet, use the cloth like floss and clean underneath the dial, all the way around the unit. Make sure you clean it thoroughly, so you don't have to assemble and reassemble it incase of failure. Put it all back together.. making sure ALL the cables are back in their original place.. and that should fixya. -Daniel
Jan 28, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
32 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
