Question about Epson Stylus Photo R1800 InkJet Printer
Dead R1800 My R1800 is unable to power up. No response to on off switch. I have checked the connections and such. Any power reset process? Thanks for any assistance.
  • cohrn Sep 09, 2007
    Thanks Davroslives.
  • 29 Answers
There is no solution to this issue other than service or replacement. If in warranty I would contact Epson tech support directly.
Posted on Sep 09, 2007
R1800 Won't Power Up
Just check the power cord of your printer it maybe don't have any lost connection or change the power cord. If did not work also their was a problem of your powersupply. You need to bring it to the electronic center technician for the proper repair of the power supply.
May 26, 2010 | Epson Stylus Photo R1800 InkJet Printer
It keeps dispaling FL in the panel
Hello, the FL displaying on the panel simply means Failed to Lock. Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Solution
Check the wire connections in harness leading from machine control board to door lock mechanism
Check solenoid and door lock enable switch in door lock mechanism.
Replace responsible component..
Thanks
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Screen froze all of a sudden. Unable to turn it
Went to on-line manual and found out how to remove faceplate and reset as advised in response on FixYa. Thanks.
Nov 09, 2009 | Garmin StreetPilot c340 GPS Receiver
Epson R1800 Printer turns OFF
Here is my solution to your problem.
Power Failure is not reason here. I think you Epson have a problem inside the circuit board.
It has two output, the PRIMARY & SECONDARY Output, one of this are not function due to power or wattage failure.
I did encounter such problem but I open my printer and I see inside its nothing but the PCB Board have leak of one of my capacitor inside.
If this case is still comes out then better to check that with EPSON PRINTER Technician.
And about resetting EEPROM it useless.
At least this information give you such ideas why you have this kind of problem. Resolving such problem are not only on talk but let our hands do it also.
I tell you one way or another, careful of that maybe it has a short circuit. Good luck!
Aug 07, 2009 | Office Equipment & Supplies
Hi my R1800 has 2 flashing red lights (top) and no power light. What can i do? MAria
Hi.
It could be your ink tray has overflowed.
There is software http://www.ssclg.com/epsone.shtml which might help.
Install this program, set your printer model and the driver (Epson Stylus Photo R1800) when it starts up. Close the program, and it will minimize to the
tray on the taskbar - right click on the icon and goto "Protection Counter". Choose
"Reset Protection Counter". Choose "Yes" to the question about the waste ink pads,
then switch the printer off for 1 minute. This should cure the problem.
It might be worth a try
Jun 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
Unable to connect to the internet
Please contact your Internet service provider.
OR check your connectivity settings
Jun 27, 2017 | Palm Treo 750 Smartphone
Epson Stylus Photo R1800 Won't print anything but head utility
If you are using Mac, make sure you choose or add the correct R1800 printer ( USB or Firewire ) to the Printer list in order for the printer to response. Hope this will help
Oct 20, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper and ink lights blinking - no power light flashing at all - can't do anything on our Epson R1800 printer... can you suggest something to try? have been doing a lot of head cleaning due to bad nozzle...
Try doing a printer check by doing the steps below. If it doesnt work, then try to call the printer manufacturer for more advanced solutions or information
  1. turn off the printer and disconnect it from computer
  2. place a plain sheet of paper
  3. press and hold down the paper feed button, then press and release the power button. Continue holding down the paper button until you see the power light flashes
  4. if it prints a test page it is working fine, the problem might be the computer settings, printer settings, software or printer application, or cables, otherwise the problem is the printer itself
Oct 13, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 Photo Printer
thanks, will post on the original post only, so please don't reply here
Jun 03, 2008 | Epson Stylus Photo R1800 InkJet Printer
My Epson R1800 keeps resetting itself
You have done all the usuall checks, but you may have a usb power problem, try the printer without any other usb peripheral in and see if it stays connected. If not, then the usb connection or workings in the printer may be faulty and keeps disconecting, hence the bing bong as it re connects to windows. You may have faulty hardware, leave the printer disconnected from usb and mains for 15 mins or so then try again.
Mar 18, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
82 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
