Question about Logitech Harmony 890 LCD Remote Control
I have lost ability to control functions on cable box. This happened overnight. I notice that the RF light on the Logitech Signal device is not lit...could this be the problem? Is there awy to re-start?
  • K & J Vaughn Apr 09, 2008
    My remote says I need to install the RF Enhancer...???? What is this, why is it coming on now and what do I need to do to correct this issue? I cannot change the channels until I do this. HELP!!!!
  • Anonymous Jan 01, 2009
    my remote works in the room where all of my equipment is but not in my movie room
Remote is not working the equment, but it will turn tv on and off
Posted on Jan 29, 2009
  • 1 more comment
  • lincthetoolm Jan 29, 2009
    how do i go throu the prosses of connecting it to the remote
    would pushing the wrong button on remote make it not work with equment
    called logitec and was given a referance #090130000296
Pull the battery out and re-insert it, also update the remote firmware
Posted on Sep 03, 2007
    Problem Solver:
  • 19 Answers
Is the rf extender plugged in?
If so, press the connect button on the rf extender, and then go through the process of connecting to it with the remote.
Posted on Jul 08, 2008
SOURCE:
I have a logitech Harmony 890 remote. The battery
To check to see if your device is controlled by a RF (radio frequency) or IR (infrared) remote:
Power the device on manually
Cover the front of the original remote that came with the device with your hand
Press any button on the remote that you know the device would respond to normally
If the device responds even when your hand is covering the front of the remote, the remote is RF and the device cannot be controlled by the Harmony remote
Another test that can be performed is using digital camera:
Using any digital camera, even one on a cell phone, camcorder or webcam, look through the screen of the camera at the front of the remote
Press a few buttons on the original remote
If you see flashes of light as illustrated, the remote is IR and the Harmony can control it. If the remote does not flash, this original remote is an RF remote and the device cannot be controlled by the Harmony remote
For comparison, try the same steps with a remote control that you know is working correctly, such as the original remote for the TV, or DVD player. You should see the IR emitters flashing when performing this test.
Feb 08, 2010 | Logitech Harmony 890 LCD Remote Control
Tip
Harmony 890 Pro Manual Download
Download Logitech Harmony 890 Pro Remote Control Manual
Have you misplaced your Logitech Harmony 890 Pro Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 890 Pro Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Televison & Video
Tip
Harmony 890 Manual Download
Download Logitech Harmony 890 Remote Control Manual
Have you misplaced your Logitech Harmony 890 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 890 Remote Control Users Guide?
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 890 Universal Remote
Harmony 890 Pro will not pair with Xbox360
The RF signal is on the XBOX is used for the controllers only.
When using the Harmony 890 with a 360, you will have to use it as an IR (infrared) device. That is the only way to use a remote with the 360. If you have an extra port on your RF extender, you can place the end on the remote senor on the 360 (located under the eject button).
I set these remotes up weekly, it is a product I recommend to people all the time!
But again, the only way to setup a remote with the 360, is to use the IR port as a standard IR remote. Since the controllers run off RF, the learn function will not work, unless you already have 360 remote control to use to do the learn function.
Hope that offers some insight. This information can also be verifies at Microsoft XBOX 360's FAQ page.
Oct 21, 2009 | Logitech Harmony 890 LCD Remote Control
Need a manual to know how to use the various menus on the remote
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony MAC Software Download
Jan 23, 2009 | Logitech Harmony 890 Universal Remote
Tip
I hope that helps.
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 890 LCD Remote Control
Logitech harmony remote 1000 not operating CBus lighting
Is there an IR receiver (or if using the RF extender, IR eyeballs connected to device and the RF extender) that you are pointing at to control the CBus lighting? If not, there is no way to control it. The Harmony 1000 will only communicate with the RF extender through Zwave, so you can't communicate with other Zwave devices, like you can with the Harmony 890 for instance.
Hope this helps,
81
Dec 08, 2008 | Logitech Harmony 1000 LCD Touchscreen...
Logitech harmony 890 display is blank
this sounds like it is a hardware issue, try contacting Logitech through e-mail from the website www.logitech.com and sending an e-mail in.
try the following before contacting them:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
If this doesnt work, provide them with the following to make sure the process goes as smooth as possible:
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Phone number:
Street:
City/Town:
Country:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
Nov 29, 2008 | Logitech Harmony 890 LCD Remote Control
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
I recommend resetting it up with your components to get rid of the two channel problem.
I hope that helps.
Nov 25, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
308 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
ray gallant
ray gallant
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
