Question about Sony Ericsson W700i Cellular Phone
Network and battery problem
1. Network problem : whenever we are moving from one tower range to another, w700i sticks with the old tower and the signal gets very feeble and enters into emergency calls only mode. we have to switch off and on back to get the good strength signal. 2. Battery: It is not charging more than 90 % Even charging more than five hrs.
    Problem Solver:
  • 7 Answers
For network problem you have to go to the connectivity through your menu and select mobile networks and change the mode to automatic and then in mobile networks check out with prefered network option.
Posted on Nov 20, 2007
Unlock code
You mean the network unlock code?You can approach Prounlocking.com and get the required unlock code for your Sony Ericsson W700i.You need to specify the country,locked network and based on the availability get the unlock code along with free unlcok instructions.
Sep 23, 2013 | Sony Ericsson W700i Cellular Phone
How do i complete the transfer of network settings(BELOW ARE THE TWO PC'S). . .FROM": **tower running xp professional (wired) to **notebook which is wirless...
Click Start
Click All Programs
Click Accessories
Click System Tools
Click Files and Settings Transfer Wizard
Use the Wizard, but "de-select" most of the settings, so that _only_ the "network settings" are saved.
Tell the Wizard to write one file to a USB memory-stick.
Move the memory-stick to the new computer.
Run the Wizard again, telling it to "import" the settings from the memory-stick.
Apr 10, 2011 | NetGear WGR614 Wireless Router
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
No network coverage signal
If you are not receiving a signal ... you are out of range. You will have to move within range of the signal tower to use your device. I suggest you contact your service provider concerning this. There is otherwise little or nothing that you can do until you get within range of the tower signal.
Thanks for your visit today.
Jan 25, 2011 | Cell Phones
I cannot connect my ipod touch to my router how do i connect it?
First you'll need to turn on your Wi-Fi.
1. Choose (Settings) then (WiFi) then (turn WiFi on)
2. Set iPod touch to ask if you want to join a new network: Choose (WiFi) and turn (Ask to Join Networks) ON or OFF.
Then you'll need to join a WiFi network (your D-Link for instance)
1. Choose (Settings) then (WiFi) then wait until your D-Link shows up in the list of networks.
2. Select your network and if you have a password for your router make sure you type it. (networks that require a password have a lock icon next to it) then tap (join)
Once you join a WiFi network manually, iPod touch will automatically connect to it whenever the network is in range. If more than one previously used network is in range, iPod touch joins the one last used.
When iPod touch is connected to a WiFi network, the WiFi icon in the status bar at the top of the screen shows the connection strength. The more bars you see, the stronger the connection.
Good Luck
Dec 25, 2010 | D-Link DIR-600 Router
I'm using w700i , My cell display the messsege "No
You are getting this because there will be no network of you SIM card.
Follow these steps to find the netowrk:-
1.Just go to setting
2. Select phone settings.
3.Then select the netwrok selection.
4.select the manual and it will search for networks.
5.Choose the options which shows your network provider.
If you face any problem then ger back to me.
All The Best
With Regards:-
Subhankar Ghosh
Nov 26, 2010 | Sony Ericsson W700i Cellular Phone
When i flip the phone open, on the main screen at the top it says "No access to net." Whenever i try to make a call the call doesn't go through and is back to the main screen. And when someone calls me,...
Have you tried shutting the phone off for about 10 seconds then turning it back on? My phone does this some times and it's just because I am out of range of a tower for the network. If this doesn't help, it could be a network problem and for that you would have to contact your network provider.
Nov 04, 2009 | Sony Ericsson TM506 Cell Phone
Please have patience with an elderly computer illiterate person. Am near a wifi tower and am interested in purchasing a eub362ext wireless usb adapter to get on line. My desk top has windows XP. Will this...
Hi spring chicken.
Two ways of going about this, cost about the same, £15 - £20. Your computer needs to talk to wireless tower, this is done by a plug in USB wireless dongle, (small stick, plugs in computer USB port) or by a wireless PCI card that fits inside your desktop in a PCI slot,(white slots on your motherboard,3or 4 of them side by side) Both ways are straight forward plug & play. You say you are near a wifi tower, this is fine as long as you are in what we call a wifi hotspot, where the owner of the tower allows unrestricted access to other users, Library's & the such allow this service. Your dongle or card will let you see if the networks are security encripted (WEP) or open unsecured. A secured network requires a network key to be used, (an 8 or 20 digit number set by the owner)
You can only get free network access in a hotspot.
Or ask the owner of a nearby network if they would be kind enough to allow to use their network, you will need a security code from them.
Hope this helps, do have a nice day.
Oct 02, 2009 | EnGenius EUB-362 EXT WIRELESS USB 2.0...
Problem with Instrument
network selection should be in automatic
Sep 07, 2007 | Nokia 6600
Sony Ericsson W700i Cellular Phone Logo
132 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
