Question about Sony Cyber-shot DSC-W70 Digital Camera
Sony DSC W70 lens stuck!
I have this camera and i just fully charged the battery and when i left it on my desk for 5 minutes in the "on" mode it turned off suddenly and the lens is now stuck open. when i turn it back on access pops up and then it tells me to turn it on and off again. after doing so it still doesn't work. i have tried taking out the memory stick and the battery then turning it back on and still no luck. any ideas??
This is what I found out on this and how I fixed it. This is all relative to my camera. What I found out was the view finder has a small detent which rides in a groove. When droped or bumped it falls out of the groove. To fix this I had to remove the lens assembly and realign the view finder guide. I was a fairly simple procedure.
Posted on Sep 18, 2007
Hi, I have a sony handycam hdr-cx160 with I bought a np-fv70 battery and my problem is that my camera turn off after I spend some time used it, Like 2 or 5 minutes. it is charged, the camera recognize the...
Hi luismasramir ,
Seems to be the case where the battery is not fully recharged , Please follow the below steps :-
  1. Please make sure that you charge your battery fully , till the time you see an indicator for the battery being fully charged , or may be you see an icon in the display screen with the charge status.
  2. As far the 6.30 hr duration that you have mentioned, this duration reflects the time that you have left for total recording space on your disk or memory card depending on your current source for recording.
  3. The above duration is not to be confused with the battery usage time.
Hope his helps ...:)
May 11, 2011 | Sony Handycam HDR-CX160 Camcorder
My nikon coolpix 8400 won't turn on, I took out the memory card to develop some pictures then I put it back in and then the camera wouldn't turn on all of sudden,it has never done this before! do you...
Make sure the battery is fully charged. If it isn't then charge it up and hopefully your problem is solved. If it is fully charged take it out of the camera for a minute or so then put it back in. Try turning the camera on.
Dec 05, 2010 | Nikon Coolpix 8400 Digital Camera
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
After charging my battery I installed the battery and turned the camera on. The lens came out and the screen came on. All of a sudden the screen turned solid white and faded to black. Now the camera will...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. turn on camera and see.if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Apr 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Flash does not work
Please note that:
1. You can not use the Flash when the Camera is set to Burst or Multi Burst mode.
2. You can not use the Flash when the ISO or Twilight mode is selected in the Scene Selection.
3. You can not use the Flash when mode dial is set to Movie.
Also try these steps and check:
4. Ensure that the battery is fully charged and the flash is turned ON.
Please set the Landscape mode or Snow mode or Beach mode in the Scene Selection and check if the flash is working.
5. Try initializing the Camera and check if it works normally.
NOTE: Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
6. Please press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
7. Try to power reset the Camera and check if it helps to resolve the issue. I suggest that you reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
8. If the issue still persists then the Camera requires service.
Good Luck!!!!!!!
Oct 26, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
180 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
