Question about Maytag Neptune FAV6800AW Top Load Washer
ND code Washer will not do anything has the code of ND
  • 1 more comment
  • Anonymous Nov 03, 2007
    not draining
  • jarrelj Jan 03, 2008
    I was washing some clothes and received the code "nd". I checked the hose and drain and everything seems ok. Does anyone have some suggestions?
  • Anonymous Nov 09, 2008
    help i have the same problem and i cant get my washer to work nd code
Followed Best Solution by jarrelj and a little bit from searstechtoo and found a piece of velcro stuck in the pump. It's pretty tight back where the pump is located. Unless you are a contortionist you will need plyers to remove three spring clamps. (1) pipe from washing tub, (2) pipe to drain, (3) electrical housing on top of pump. You'll have one more electrical plug that pulls out easily. When you remove the first line from the washing tub make sure you put something to catch any remaining water in tub. I had a lot, small bucket didn't hold it. Lots od towels used. Very hard for me to get back together. Maybe I didn't have to take so much apart, but I needed to take the pump all the way out of the unit to even see what was in there.
Posted on Nov 05, 2008
I was able to solve my ND code issue by removing an object from the drain motor (a toothpick!):
Here's how to do it:
  1. Swivel the top of the washer back after inserting a flat head screwdriver into the left and right sides of the top of the washer (between top panel and front). You can determine where to put the screwdriver by looking under the rubber gasket at the front of the washer.
  2. Inside the front panel (at the top) there is a screw on the left and right side that must be removed in order to take off the front panel.
  3. Once the front panel is off, under the wash bowl, on the right side, you will see the drain hose which can be removed by using a screwdriver to loosen the clamp on one end and pliers to squeeze the clamp on the motor end to remove it.
  4. Once you've removed the hose from the motor, you can twist the motor to the right to take it off the mounting base.
  5. Use a screwdriver to open the flap to see if anything is inside the motor (like a toothpick!) or look into the motor through the end where you removed the hose.
  6. Remove the object and follow the directions in reverse to put it back together.
Good Luck!
Posted on Jan 05, 2008
I had the same problem. nd code on the display, removed the drain pump from the back right bottom corner of the machine and found it clogged with plastic assuming it came from the dogs bedding put it back together and the machine works fine. You can find out how to remove the pump on this page or if you want help email me i will give you my number and I'll walk you through it. I will do this just because I'm so happy this site saved me the money on calling a repair guy. randvs@yahoo.com
Posted on Mar 08, 2009
  • baddable Dec 19, 2010
    Followed jarrelj's instructions. Found a 15" piece of rubber gasket (from the washer tub) in the drain line, partially entering into the pump. It had tied itself into a knot and formed the perfect plug! Fortunately I could just pull the piece free and reattach the drain line w/the clamp and be done.
    15 min in and out thanks to jarrelj's steps. Thanks!
"nd" code on my washer, after I moved residence what would cause that?
Nd = no drain. Either drain pump is clogged or defective. Too many suds can also cause this problem.
Oct 05, 2017 | Amana Washing Machines
Nd code and door locking
There could be another coin in the drain pump, jamming it.
With power disconnected..........Does the pump turn by hand in both directions?
Nov 21, 2017 | Maytag NFW7200TW Front Load Washer
New pump installed, still not working and nd code
look at ( have a technician look if you want to save money) at the program board for a problem there
Apr 25, 2017 | Samsung WF328AA Front Load Washer
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
I am getting code nd on my maytag neptune washer. how can i fix?
ND code is "no drain" the washer probably has a drain plug/filter on the main pump, more than likely all you need to do is clear debris from the pump.
Jun 20, 2012 | Maytag Neptune MAH9500A Front Load Washer
My washer stopped working and is displaying the code nd, what does this mean?
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Maytag NFW7200TW Front Load Washer
What does the code nd stands for on the maytag front load washer?
ND No Drain Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer. 1.Check for pump/drain restriction. 2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
May 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
What does the code nd stand for?
this is a no drain error or slow drain issue you need to check for anything that would or is restricting the water from draining out of the tub.
if the water will not srin then you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
then check all your hose to and from the drain pump
Apr 13, 2010 | Amana LWA40A
Maytag Neptune FAV6800AW Top Load Washer Logo
261 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
