Question about Maytag MSD2756G Side by Side Refrigerator
My 9 month side by side refrigerator
It has been having problems. It went from making great and a lot of ice, to hollow ice and now none. I tried turning the setting up, down mid=-way, everything. I called Engles in Fort Smith, arkansas and they said to call whirlpool; but did not know the phone #..Didn't whirlpool buy out Maytag? I called several repair men and they said they have never completed fixing a maytag ice maker.. Help. Sherry (wilmoth) nickname)
Hollow ice would suggest poor water flow due to a blocked water filter, check the water flow before and after the filter, make sure you flush the water line out before fitting a new filter. Cheers Colin
Posted on Aug 13, 2007
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Water dispenser and ice maker not working properly.
If the water flowed normally for a few years and now will not fill the ice maker with enough water to make full size cubes or dispenser fill too slow the problem may be a defective=> 67005154 Water Inlet Valve In the tutorial above I want you to listen carefully of all the possible items that can cause slow waterflow. I am here should you have questions Thanks Sea Breeze
May 25, 2013 | Maytag 26 cu. ft. Wide-By-Side...
My wide by side Maytag refrigerator MZD2768GEB ice maker is making hollow ice. It seems that it is not cycling properly as very little ice is in the bin and most of the time the hollow ice is stuck to the...
Hi
Hollow ice is a sign of not enough water going into tray. Replace the water inlet valve or the fill and shut-off valve for problems with both parts. Hollow ice cubes usually indicate a low water problem. This is generally the result of an excess buildup of calcium and other deposits.Replace the self-piercing shut-off valve with a drill-type shut-off valve.Drill a 1/4-inch hole into the pipe and installs the shut-off valve the same way you would have installed the self-piercing valve.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Maytag MSD2651 HE Side by Side...
Water/ ice issue
this problem is either low water pressure or a faulty water inlet valve. if u have good pressure, change the valve. repairclinic.com
Jul 25, 2009 | Maytag 25.6 cu. ft. Side-By-Side...
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Icemaker - hollow or solid ice, take your pic!
check behind the bottom front panel, mine has instructions for changing the water flow. If the instructions aren't there try your manual or an online one.
Jun 11, 2007 | Whirlpool GC5SHEXNS Side by Side...
Hollow Ice- Slow Ice!!
Hollow ice is a dead give away that there is not enough water filling the trays. Check that the line isn't pinched from pushing the unit back in place, etc. Also check any filters or filter screens in the water line to the ice maker.
Jan 13, 2007 | Kenmore 55692 / 55694 Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
141 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
