Question about Sony KDS-R50XBR1 50" HDTV
Connecting PC to sony SXRD with RGB cable no display?
I am getting no dispay from my PC notebook after connecting it to my 50" Sony SXRD. I have set the TV to Video 8 as it says you are suppose to but there is "no signal" is what it says. Anyone know what I am doing wrong??
    Problem Solver:
  • 8 Answers
How are you connecting the PC to the TV (ie which input and what type of cable are you using?)
Posted on Aug 14, 2007
SOURCE:
Hdmi 6 and 7 do not work
HDMI does not like connections made with units powered and or on.
Try removing power from the units connected and the set for a while, reconnect them and then connect power to see what happens.
Most Sony sets have a reset but try the suggestion above first.
Dec 03, 2012 | Sony Grand Wega 50 in. Diagonal Class Full...
Connected laptop to hdtv via rgb lead but no sound from 2nd monitor(tv)
Sadly, RGB cannot carry sound. In order to hear the laptop sound on the television, You'll need to get an 1/8" headphone connector to RCA (White and Red plug) cable and connect it to the same input as the video is plugged in.
Aug 23, 2011 | Sony VAIO VGN-N130G/W Notebook
How can i connect my pc to sony bravia kdl-40ex403
Things You'll Need:
  • 15 pin RGB cable
  • Audio cable
Step 1
Connect the RGB cable to the Video Out jack on your computer.
  • Step 2 Plug the other end of the RGB cable into the RGB jack under PC In on the back of the television.
  • Step 3 Hook up one end of the audio cord to the Audio Out jack on the computer and plug the other end into the Audio jack under PC In on the back of the television.
  • Step 4 Turn on the television and press the "Input" button on the television or the television remote control. A list of input options will appear on the screen.
  • Step 5 Highlight "PC" using the up and down arrow buttons and press the "+" button to choose the computer input. The television will display whatever is on your computer.
  • May 01, 2010 | Lenovo 3000 N500 Notebook
    Sony SXRD has a greenish tint on everything.
    I believe it is called the "light engine" is going bad. The Sony SXRD is NOTORIOUS for this going bad. So much so that there was a class action lawsuit that extended the warranty. My 50" SXRD went bad after 12 months. Because of the class action lawsuit, it was basically fixed for free.
    Jul 11, 2009 | Sony SXRD VPL-VW200 LCD Projector...
    Can't connect my mac mini to my television
    How are you connecting? Do you have an RGB connection on your TV? There is RGB cables that convert too DVI or Composite. Check your local computer store.
    Jan 29, 2009 | Sony PlayStation Portable (PSP) Console
    Connecting Toshiba Lap Top to NEC LCD TV
    From user manual (page 68):
    Your computer comes with a built-in display panel, but you can also
    connect an external display device to an available video port, as
    follows:
    ❖ An external monitor or projector via the RGB (monitor) port
    ❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
    Before connecting an external monitor or video projector, configure
    your computer for the type of device you are connecting. To do this,
    refer to the documentation for your operating system and devices
    So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
    Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
    Configure your extended screen using your manual instruction:
    Once you have connected an external display device, you can
    choose to use the internal display only, the external device only, or
    both simultaneously. The quickest way to change the display output
    settings is to use the display hot key (Fn + F5):
    1 Press Fn and F5 simultaneously.
    2 While holding down Fn, press F5 repeatedly until the setting
    you want takes effect. Briefly pause each time you press the F5
    key to allow time for the display to change.
    This hot key cycles through the settings in the following order:
    ❖ Built-in display only
    ❖ Built-in display and external monitor simultaneously
    ❖ External monitor only
    ❖ Built-in display and TV
    ❖ TV only
    Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
    Connecting pc to tv
    You need to toggle to the external display by holding the Fn key + F7 or F8. Look at your keyboard and you'll see little TV screen icons. You can also go to start/control panel/display settings or right click on your desktop and access the display properties.
    There is usually two tabs with two displays and the active current display in from. Click the other and adjust the resolution and type using the drop down menus.
    You might need to consult your TV manual as well to make sure your in the right input mode.
    CR
    Aug 04, 2008 | Computers & Internet
    Connecting dvd?
    If everything is connected and dvd player is on, make sure you have the proper input selected on the TV. Input2 on this model TV. Try switching between the inputs.
    An important thing you need to do is set the RGB input signal from PC to YUV or you won't have a good picture. This is done through the menu system
    Jul 01, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
    Sony pfm42x1 colour problem
    Check the settings in the menu and make sure you have the input properly set to RGB and not color difference settings (Y, RY, BY).
    Apr 22, 2008 | Sony PFM-42X1 Plasma TV
    No digital to reciever??
    This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
    Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
    Sony KDS-R50XBR1 50" HDTV Logo
    271 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
