Question about Hitachi 43UWX10B 43" Rear Projection Television
Only the red light work
I have hitachi43uwx10b and when turn on the unit the red light work but the sound and picture no work I was check the antenna and I was try with another channel
    Genius:
  • 1,694 Answers
Repair usually involves E994 2 amp pico fuse open and C702
capacitor shorted==102K/2KV, replace with Sony part #
1-161-754-00  102K/3KV for durability.Requires chassis pull .
Posted on Oct 18, 2007
SOURCE:
Jvc tv lt42ex18 no picture but blue light come on
if it's no sound on the unit then check the antenna cable or the RC jack of the dvd player if connected right but if it 's having sound but no picture then there is a problem with video input connection or video amp. itself.
Aug 26, 2012 | JVC 29" Flat Screen Multisystem TV
Our problem is that the red light flashes 10 times and then it turns off we can hear sound but cannot see a picture we have turned it on with a friend on an outside antenna and it works but through...
If you were able to get it to work with one signal source but not another, the poblem may be with the foxtel cable rather than the tv. Was there a difference between the connection from the aerial antennae and the cable? Have you checked to make sure another tv works on the cable from that location?
Jul 17, 2008 | Sony Televison & Video
Olevia 242 TV.... No picture or sound!!!
A blue screen usually is present if no signal is connected to the set---hook a DVD up to one of the rear inputs--select that input and see if have picture and sound.
If that works connect cable or antenna to set and select that input
NO signal is like no gas in car---it will not run.
Mar 22, 2012 | Televison & Video
No picture on my lcd tv, sound but just a black screen, no warning of something wrong, just turned on tv one eve and no pic.
1 Check the antenna/cable connection 2 Connect the TV to the AC power outlet and press power button on the TV 3 When the indicator light(standby) lights up in red, press the on/off switch on the remote. 4 If this does not work, reset all settings to factory settings by going through menu and selecting settings
Jan 14, 2010 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Unit makes sounds but no display
Hi
If unit is as per pic I assume it has external antennae. Ensure the multi pin plug is secure in the rear of the unit and also use a fully charged 12 volt battery, Has it been working before?? Usually a rear plug problem. How old is unit. Just had a another thought, check that the polarity is correct, ie pos wire to RED (Pos) on battery. Very polarity sensitive.
Cheers cbacer
Aug 12, 2009 | Garmin GPSMAP 178C GPS Receiver
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Red Lights
Thoroughly check your antenna connection, be certain the plastic grommet is in place (and not cracked) between the bottom of the antenna adaptor stud and your antenna mount, and check for corrosion in and around your antenna connections. If using a fiberglass antenna, check for cracked outer insulation. If a whip, be sure the Allen screws are tight and the antenna is getting a good connection. If you have a base-loaded whip antenna (Wilson 2000) make sure the base coil plastic case isn't cracked. If you find anything wrong, invest in a new antenna. If all that checks out, buy a new 18 foot piece of coax (around $20, or get the best quality you can afford) and run it to the antenna. You may have skinned the coaxial shielded outer insulation somewhere in the uninstall/install process, it only takes one tiny break to cause problems. Be sure not to run the coax through the door jamb or a window where it WILL be pinched and cause trouble, take time to run it under the dash and out a permanent vent access or through the firewall.
Nov 20, 2006 | Cobra 29 LTD CB Radio
No picture or sound
When the red light is on, can't you turn it on by pressing channel up on the set, or power on the remote? If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Its possible that a capacitor has gone bad. You'll need to work on that, and then readjust the set. Not a major repair. When you open it up look for dry soldier joints and resoldier if necessary. good luck
Apr 16, 2006 | Samsung HCN436W 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
61 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
